Results 1 to 12 of 12
    Rider, Builder, Dreamer
    Reputation: sambs827's Avatar
    Dec 2008
    New map and signage for developed trail system
    I'm writing a long-term master plan for a 276 acre property owned by my college. Right now the trail system consists several trails named only by color. This is a remnant of when there were only three trails on the property: Red, Blue, and Yellow.
    My goal is to redo a lot of the signage and maps as we move forward with the master plan for the property. I want to have numbered trail intersections, and give the trails all real names. The Red Trail should remain the Red Trail, since it has been there for over 100 years in some form or another and has had its name for over 50. The others I am trying to convince the landowners to use names that have some significance to the experience one has on that trail or something about the history of it (not cheesy college-history related names like the managers want).
    Links to the existing map are below. Yes, it is in two separate pieces. No, I have no idea why.
    http://www.oneonta.edu/oas/collegeca...or_hiking1.jpg
    http://www.oneonta.edu/oas/collegeca...or_hiking2.jpg
    I'm compiling examples of trail maps that use named and/or color-coded trails and numbered intersections to show the land managers. Any examples or wisdom would be greatly appreciated. Cheers!
    Sam
    Go ride your bike.
    Go here Soaring Eagle and open the pdf, and you'll see a map where they numbered the intersections and named the trails. Only problem is their signage: they sign the intersection numbers but you can't tell which trail is which from the signs (users have been embellishing them with sharpies to help navigate). This is Soaring Eagle Park in King County near Seattle. Park staff like the numbered intersections to ease of reporting problems like big wet spots, blocking deadfall, etc.
    Reputation: traildoc's Avatar
    Sam:
    Bend, Oregon has one of the best mapping systems I have ever personally enjoyed. They number their intersections and name all their trails. Here is the link (Bend, Central Oregon Mountain Biking & Hiking Trail Map- Phils Trail, Peterson Ridge) to the website that produced the map and their plans for the future with smart phone navigation.
    Attached is a picture of the map in a smaller format than the original picture that I could email to you if you like.
    I agree with TF about the actual signs that point to the trails leaving the numbered intersection. Many landmanagers do a poor job of showing the actual direction of the name of the trail leaving or entering the intersection. This often happens when the intersection is not 90 degrees to the sign post that might be a squared post.
    In Sedona I asked the FS to use round sign posts to be able to adjust the sign to the angle the trail intersected the sign post. They finally came around to my suggestion, but it was a difficult process.
    I also posted a picture of one of the signs that makes Bend a great place to ride.
    Attached Thumbnails Attached Thumbnails New map and signage for developed trail system-bend-mapa.jpg
    since 4/10/2009
    Reputation: Harold's Avatar
    numbered intersections and named trails work great, IME. I have also ridden trails where letters or numbers are spaced out at some set distance along the trail to aid in emergency response. EMT's seem to like that, but it tends to require some emergency access points to more remote spots along the trail to be considered.
    Hermit
    Reputation: swampboy62's Avatar
    Here's a map I developed for West Branch SP in northeast OH. They've marked each intersection with a carsonite post with the intersection number, and then put the name of the trail on the posts at each end. It seems to work very well with new riders.
    Steve Z
    Pedaling when it's dry
    And paddling when it's wet
    My insignificant blog:
    http://swampboy62.blogspot.com/
    Quote Originally Posted by swampboy62 View Post
    Steve:
    If you get a chance can you post some pictures of an intersection marker where a trail crosses another trail and the individual (four?) trail markers that are placed to show users which trail they are now riding on.
    In Sedona one of the big problems with trail markers is the rocky nature of the soil that the marker post is placed in. Many times the surrounding area is SOLID rock, so the landmanger builds a large rock structure around the marker post to hold it in place. I wish there was a good inexpensive way to add trail markers in rocky soil that the landmanger would not have a problem with.
    I've seen a few examples of this in Bend.
    I like the idea of a number post at the intersection and a name at the trail entry. It costs more but it doesn't leave people sitting there scratching their heads.
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Here's what I came up with at the request of the park manager. He and the local EMS get the map with the GPS coordinates. The simplified map with the letter-number code goes up on a post on the trail. There's a new letter at each trail intersection. The user guides are posted at the kiosk at the trail head.
    What I've attempted to do is:
    -Provide way to locate an injured trail user for rescue by the park rangers or local EMS crews. This was the main request by the park manager.
    -Show trail users where to head for the nearest bail out.
    -Give trail distances to and from the trail head
    -Give a simplified set of trail loops to choose from for first-time trail users. Having a simplified map for the trail users was a vital part of the project because there are dozens of trail intersections and new users get overwhelmed with too many possibilities.
    In addition to these signs, there are full maps showing all roads and trails in the park at most major intersections. I'm also putting in color coded (matching the loop color) arrows showing which way to turn at intersections where that isn't obvious.
    Obviously, phone contact information is of limited usefulness if the trail user doesn't have reception, or a phone.
    Setting posts in this property is work. In the good spots, it takes 30-60 minutes with a rock bar and post hole digger. I've made as many as 5 attempts to get a decent hole depth (> 24") before getting lucky. It's a combination of lots of rock, and hard clay under silt soil that make it special. I guess that's why the last glacier went around instead of over.
    Walt
    Attached Thumbnails Attached Thumbnails New map and signage for developed trail system-short-mound-map-trail-markers-small.jpg
    New map and signage for developed trail system-map-guide-2-small-version.jpg
    New map and signage for developed trail system-map-guide-3-small-version.jpg
    Quote Originally Posted by warmonkey View Post
    Amen Brother! What is interesting about Bend is that a lot of the signage is way up in the trees for the cross country skiers.
    Dec 2008
    Thanks for the responses. This should be quite helpful. Another question came up in a meeting today regarding some old fitness stations that used to be on the trails. Anyone have experiences with these?
    I'm talking stations for pull-ups, push-ups, abs workouts, balance, etc.
    Go ride your bike.
    Aug 2010
    Here's some new signage here in the PHX area.....
    Attached Thumbnails Attached Thumbnails New map and signage for developed trail system-img_20120914_164053-1-.jpg
    Dec 2008
    Good job! Revisions Complete!
    I forgot to post the final revision, so here it is:
    Presentation1.pdf
    It's a dumb version of the map using a lot of what was created almost 10 years ago. A couple students with the Geography Department are doing an internship with some serious GIS work on the college and on College Camp, and they will compile a database with cleaner-looking maps. For now, this is at least good enough for people to figure out where they're going.
    I'm getting out with the property caretaker next week to start remarking everything. I've already gotten loads of compliments from student groups and professors who use the trails for their activities and classes, so I guess it makes sense.
    Also just got word of permission to include this map in a comprehensive trail map of the 30+ miles of trail in this town; that's another internship I'm working on for Otsego County Tourism this semester. Super stoked that everything is falling together, especially since there used to be huge opposition between the property managers (OAS) and anyone any way associated with bicycles. It's great what a bit of patience and cooperation can accomplish.
    Go ride your bike.
