Results 1 to 11 of 11
    Jul 2013
    My McLeod look alike tool
    What do you think about the look alike McLeod trail tool i made here at work. I work in sales at a stainless steel service center here in Houston & have access to our plasma machine. It has 7 teeth instead of 6 and it's shaped a little different, the flat side is sharpened for cutting roots & stuff like that. It's a little heavy at 10.5 lbs. but i can probably lighten that up if i use 10ga instead of 3/16" thk plate and a thinner wall for the tubing on the handle. It should get the job done. My McLeod look alike tool-trail-tool-001.jpgMy McLeod look alike tool-trail-tool-002.jpgMy McLeod look alike tool-trail-tool-003.jpg
    Reputation: Maday's Avatar
    Nice... 10.5 lbs It will let the tool work the way it should. Just make sure you only let people with a strong handshake us it.
    - Be Someone
    Dirt Monkey
    Nice work. Those look like they could take some punishment. Are they stainless steel?
    If the weight is an issue, a wood handle could probably shave off a pound or two and you wouldn't need to worry about it bending or kinking like a thinner wall tube might.
    It looks like the handle is attached to the head with threads? Have you considered it may try to unscrew itself during use? If it is a problem you could drill a hole through the coupling and put a pin through both parts to prevent rotation.
    Jul 2013
    The head & the coupling is stainless since that's what i had on hand, the handle is 3/4" carbon gas pipe in got at Home Depot. I haven't used it yet so i'm not sure if it's going to come loose or not, it tightens on pretty tight even tighter with a pipe wrench, but if it does come loose during use i have consider what you sugested about the pin, i would have welded the handle on, but wanted it detachable for transporting into the feild.
    The handle looks nice and long so it wont be too hard on your back. Would be nice to have some grip stuff on the handle so your hands wouldn't get so tired when you have wet muddy gloves. You could use thread lock to keep it from unscrewing. I like the smooth, it will help prevent clay build up when using it as a compactor.
    There's a big difference between ripping and skidding. Those who skid don't know how to ride.
    WillWorkForTrail
    Jun 2012
    wow, if the head of that thing is 3/16 it should be nearly indestructible. All of the commercial stuff I've seen is much lighter than that.
    Jul 2013
    Quote Originally Posted by Cotharyus View Post
    Yes i agree it's not going to bend, it's stout.
    Jul 2013
    Quote Originally Posted by Dave_schuldt View Post
    Maybe i can use tennis racket wrapping or something for the handle, i do agree it probably needs something, it's pretty slick.
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    Quote Originally Posted by se.tx.mtber View Post
    Try one of these.
    Quote Originally Posted by Trail Ninja's Son
    You may be happy to hear that my dad has kicked cancer's ass. Now he's looking for whoever sent it.
    Reputation: geekonabike's Avatar
    Jun 2010
    Maybe add a locknut if it tries to back out. I like the removable head for transport.
    . Later, mike
    . www.geekonabike.webs.com
    Jul 2013
    Quote Originally Posted by geekonabike View Post
    That's a good idea, that could work also, I'll have to check it out. Thanks for all the suggestion, maybe i will make some more & sell them cheap to whomever might be interested.
  1. Best McLeod Tool? Best Value McLeod tool?
    By KnifeKnut in forum Trail Building and Advocacy
    Last Post: 6 Days Ago, 12:17 PM
  2. Need to order a McLeod, any favorites
    By R900 in forum Trail Building and Advocacy
    Last Post: 05-25-2012, 07:45 PM
  3. Alike 110 Parallelogram Fork
    By DaGoat in forum Shocks and Suspension
    Last Post: 01-24-2012, 08:00 AM
  4. Not all Big Fat Larry's built alike?
    By rocwandrer in forum Fat bikes
    Last Post: 09-30-2011, 04:23 PM
  5. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
