Results 1 to 11 of 11
    cordless chainsaw
    Anyone tried one?? Do they work???
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dmgrapid
    Sure, they are gas powered. Work VERY well.
    mtbtires.com
    Takw/agranofsalt
    Jan 2005
    Yes, I have a Ryobi 18v. It works pretty well for soft woods up to about 10" in diameter. Harder woods like oak and madrone will drain the battery pretty quickly. On the plus side, it is quiet, light weight and worth the price IMO.
    Thanks for the info., suppose I could have worded it battery powered. Glad somebody knew what I was talking about!!!
    Takw/agranofsalt
    Jan 2005
    no worries, just make sure whatever model you buy to get at least two batteries. Last I checked the Ryobi is not made anymore(?) but check Amazon.com. There are some others like the Black and Decker.
    discombobulated SuperModerator
    Jun 2005
    What about the cordless recip's? Like a sawzall...Man Have I wanted to have one of those more than a few times...
    CDT
    Takw/agranofsalt
    Jan 2005
    Quote Originally Posted by CdaleTony
    CDT
    A recip can only cut through max 4-5" diameter. A 10" chain saw can cut through much wider stock.
    edit: Not to mention the narrow blade of a recip will bind long before the wide cut of a chainsaw.
    wot no bike?
    Reputation: pahearn's Avatar
    Feb 2006
    Quote Originally Posted by Khemical
    Case in point, I used to use my Milwalkee 18v Sawzall to prune the stump on our Christmas trees and it was a pain in the ass compared to the gas chainsaw.
    pete
    I use an 18v DeWalt recip on the trail, and it works well for the smaller stuff with those heavy pruning blades. The challenge with these saws is that they have a stroke of only an inch or so. That's not enough to clear the sawdust in a log of any real size and so you end up cutting sawdust instead of wood. What does work is to keep the saw in motion around the log so that the sawdust can clear and the blade can make contact with fresh wood.
    I only use it because a chainsaw is not an option on some of our trails. It's not a substitute.
    I never understood electric chainsaws...
    I haven't cleared any trees on trails, but I run an 18" Husqvarna
    Reputation: PAINpusher's Avatar
    Quote Originally Posted by black hills tj
    ...some of us need to work under stealth conditions, so the luxury of gas powered saws does not exist. I feel even the electric is too loud for my purposes, which leaves just hand saws for me.
    Hydrate or Die Trying
