Results 1 to 35 of 35
    Jul 2017
    Clearing Trail Tools
    What tools do you use to clear a trail?
    In the woods here it's tough work clearing dead wood and stumps (which we usually chainsaw in to mini kickers)
    smartass
    Reputation: amish_matt's Avatar
    Depends on what needs cleared.
    For downed trees and bigger stumps, a chainsaw. For smaller woody brush, a power scythe works well. Then dig out roots with a hoe, pulaski, or something like that.
    You can get a lot done with a machete if you don't have to remove anything that needs a chainsaw.
    Reputation: JustMtnB44's Avatar
    For clearing trees/branches/brush I use a chainsaw for big stuff, folding saw for medium stuff, loppers for smaller stuff. Power scythe / hedge trimmer for dense brushy or weedy areas.
    To clear the ground usually some type of Rogue Hoe to scrape the surface, dig out stumps, bench cut, clear drains, etc.
    I can do a lot of work with my Silky folding saw and Rogue 55HX hoe.
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by JustMtnB44 View Post
    This right here, although I prefer a proper McLeod over a rogue hoe in most cases, unless I have to cut through a lot of roots.
    Moderator Moderator
    Reputation: Harryman's Avatar
    Silky saws/loppers for clearing, then pick mattocks, rogue hoes, Pulaskis, McLeods for tread. It all depends on your particular environment.
    Jul 2017
    That Rogue 55HX looks like a great multitool for the job
    Aug 2016
    Rogue hoes are awesome for scraping drains and shaping/smoothing clay tread but rocks are murder on that awesome blade with any kind of chopping motion. A guy once took my brand new Rogue during a build day and started hacking granite rocks. Geez.
    You really need a pick axe to grub out roots, small stumps and protruding rocks if there's a lot of that to deal with.
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by Bikefaceyall View Post
    That's the tool they didn't make when I started making my own trail tool. I like mine better, for a lot of reasons, but in terms of function they are nearly identical. When I hand build trail I only carry one tool in each hand, and my custom tool gets one hand, a 16" Lamberton Rake gets the other hand.
    May 2013
    My usual go to tools are a pick mattock, a square shovel and a rock bar. Loppers for clearing corridor and the small stuff. But we have been doing a lot of work in the high desert sage brush lately. Forest service / BLM does all chain saw work ahead of time. If we have to do some tree work a pruning saw such as Silky, or a cross cut saw are what we use.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Usually a pulaski and a sharpened zak trail shovel.
    I ride with the best dogs.
    Quote Originally Posted by Cotharyus View Post
    Yeah since it's basically a large cutter mattock it's great for roughing in trail tread, scraping out drains, cutting out small stumps and roots, and chopping through small logs that are on the ground. The only thing it doesn't work well for is tamping or moving large amounts of dirt since the hoe side is not flat on top and smaller than the other Rogue hoes.
    Quote Originally Posted by Clayncedar View Post
    We don't have a ton of rocks around here and I agree a pick axe is needed for rock and rocks kill Rogue hoe edges. But most Rogue hoes can chop through roots and stumps just fine if kept reasonably sharp.
    WillWorkForTrail
    Jun 2012
    Right. My tool uses a hoe that's actually a tad LARGER than a standard Rogue. The downside is, some people feel like my tool is a little heavy. The upside is, it cuts well, it works very well for tamping, and you can drag dirt around with it pretty well. Also, I used a long handle on mine, so tall people don't have to constantly bend over to use it.
    Reputation: HypNoTic's Avatar
    Larger than a Rogue Hoe? The 80R is already 8in wide. If you need larger than that, use a McLeod maybe?
    My crew mostly work with a 80 behind the machines, but for handwork, we prefer the 70H (7in wide).
    I build trails for moose & beaver
    PTBA member
    Aug 2016
    Quote Originally Posted by HypNoTic View Post
    I use the 80R and don't find it unwieldy at all.
    McLeods are not popular with builders in my part of Pennsylvania. Stuff here is either soft clay and small roots that a Rogue scrapes through awesome or else big rocks and thick roots intertwined that you need a sharp pickaxe blade to deal with.
    My crew used club-bought McLeods one time and ditched them quickly as useless. I was curious whether they work better in sand, gravel, or deep pine needle organic material found elsewhere in the U.S.?
    WillWorkForTrail
    Jun 2012
    Again, those are newer models I think. The old standard Rogue - back when there weren't a bunch of options - is what I say mine is wider than. Because mine are hand made, literally from old agricultural disc blades, some of which are different sizes, I'd say mine vary from 5" to 7" wide and are very much shaped like a slice of pie with a bite cut off the center. I leave the original cutting edge, because it does what it was designed to well - cuts into the ground.
    McLeods are useless in this area. All we have is rock and clay. Too much real cutting needs to be done to dig. Hence the use a 16" Lamberton as a finishing tool.
    I agree, I'm having trouble envisioning what types of soil McLeods work well for. Soft, sandy, dry soils maybe? I agree they are not very useful here in Western PA either. I have one and rarely use it. We use Rogue hoes 95% of the time for both building new trail and tread maintenance.
    saddlemeat
    Aug 2003
    ^McLoeds work well for clearing back forest duff to expose bare soil. A heavy duty rake and hoe. That's about all they work for, without breaking.
    Aug 2016
    Quote Originally Posted by bsieb View Post
    Makes sense.
    Where I am in SE Pennsylvania, there just a thin layer of dead leaves, a little mineral soil, and then straight to red clay that the Rogue loves.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    NE trial building...
    Cutter Mattock. Heaviest one I can find. One hand.
    Fire rake or McLeod. Removes duff and weeds and brush, and builds berms. Other hand.
    Nippers in a pocket.
    Corona folding saw in side pocket. I found Silkys to be way over rated, and pricey.
    Flask of water in the other back pocket.
    Tried all sorts of Rogues, and other gadgets over many years. The setup above is the most portable, fast, efficient, effective setup I've found for our terrain.
    Chainsaw work is typically saved for a different day.
    WillWorkForTrail
    Jun 2012
    Have to see if this works - for scale, the tool half in the picture bottom left is a 16" lamberton rake. The handles on these two tools, when side by side, are actually very close in height.
    https://www.instagram.com/p/lsZegZiz...n-by=cotharyus
    May 2013
    We worked on about a mile of trail last weekend. The forest service dropped us off at eight o'clock Saturday morning and picked us up again Sunday afternoon. We had two 8" Roque Hoes among our tools. I am thoroughly impressed with that tool in the right situation. Great for chopping sod and shaping turns.
    Aug 2016
    Quote Originally Posted by endo_alley View Post
    Agreed. Nothing cuts blocks of non-rocky ground out faster than a Rogue.
    Or perfectly shapes existing hardpack clay trailtread as needed for placing new drains, berms, etc.
    May 2013
    Tried a Rogue hoe last week. Rogue hoe works well.
    Quote Originally Posted by Harryman View Post
    We have very rocky soil, mostly limestone, with lots of trees in central texas. I use basically the same thing.
    Ill do a hedge trimmer to cut through vines and brush along with the silky big boy and mark the trail. Then I come through again with the silky and a pick mattock to bench cut, cut roots, and really open up the trail. I use the pick mattock sideways to scrape off all the loose scree. Then finally a mcleod to smooth the tread and widen it.
    I dont love the mcleod and based on the thread, might try a rogue hoe. Some people recommend sharpening the mcleod.
    Aug 2016
    Quote Originally Posted by goodmojo View Post
    I dont live the mcleod and based on the thread, might try a rogue hoe. Some people recommend sharpening the mcleod.
    You said you have "very rocky soil" which puts that beautiful rogue blade in jeopardy unless the pick mattock is taking all the punishment in chopping out rocks and removing scree.
    Is your ultimate trail tread primarily claybased? If so, sounds like the rogue works.
    If more sandy, maybe the lighter McCleod sharpened up would work better. Here in Pennsylvania, McCleods feel almost useless.
    There is no sand or clay. It is 100% rock mixed in with a little soil. Some areas have some nice dirt, but maybe about 6 inches max before hitting limestone. The pick mattock does the majority of work, then the mcleod just levels everything out.
    Even the mattock blade is often too wide, I use the pick to punch a hole and then lever rocks out. The wider blade is usually to bench cut shallower areas with less rocks. The pick always seems to be able to find the small gap between rocks.
    Aug 2016
    I'd say skip using the Rogue altogether on that. Pick mattock sound like the only game in town as you already know.
    MA trail builder here, rogues, all good. McLeods are great for getting down to the mineral layer. The duff might be 2-6" deep. Raking and roughing out the line too. Great for packing the dirt back down as well.
    Jan 2014
    Battery powered Lion Sawzall FTW
    Don't post, ride.
    saddlemeat
    Aug 2003
    ^Which blade do you use to cut the stump out?
    Reputation: watermonkey's Avatar
    ^^^Pruning blades on sawzalls are awesome. Its pretty amazing what those things chew through.
    I would advise not taking my advice.
    Jun 2005
    Where I build (Vancouver Island, BC), the terrain is typically glacial till or rock with moderate to dense bush coverage (e.g. salal 3 feet deep). I build technical DH style trails and usually build solo. About a year ago I started using a Stihl HLA65 battery powered long reach hedge trimmer for corridor clearing and it has bumped up my output massively.
    With this system, I:
    1) clear all the logs/etc from the corridor;
    2) make a first pass with the hedge trimmer. This typically leaves a few 6" protruding stems and some missed bushes;
    3) rake the bush trimmings/surface organics downhill in a way that does not impede drainage;
    4) give it a second pass with the hedge trimmer;
    5) give it a second rake; typically this removes all organics in my terrain.
    Depending on the terrain under the bush, that process can be enough to result in a rideable route. Then you can get into the dirt work without worrying about spoiling your mineral soil with organics.
    Jan 2016
    Edmonton Alberta. X inches of organic then clay. Absolutely love small machete for anything under 2". I try to choose a line that leaves all trees and use fallen stuff for berming. I use a Maddock to bench trails but i try to pick a line that needs as little work as possible.
    Small electric chainsaw for stuff i cant move or a cross saw.
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Tools of choice depend on the soil and vegetation.
    Some areas have lots of brush and saplings. If the rock content is low enough, a sharp Rogue Hoe is the most efficient tool I've found for cutting through small roots. Roots bigger than an inch in diameter usually cut faster with a Pulaski. If there are lots of rocks, the mattock side of a pick is the way to go. Cutting bigger roots with a mattock is very slow. It's usually worth the time to completely excavate around it and cut with a Pulaski.
    There are lots of rocks where I work. A steel digging bar is an essential tool, one I carry for nearly all new trail clearing. I've started carrying a 4 lb Trow and Holden Stone Buster* hammer for smoothing off tire rippers. (Lots of chert in this area, it fractures like glass.) I've also invested in a Makita rotary hammer and a set of feather and wedges. Currently I'm limited to working areas where I can wheel in a generator, but next year I will purchase a Honda EU2000 generator and a pack frame so I can work in more remote areas. This is way overkill for most trails, but I've been fighting difficult rocks for a long time and this set of tools has opened up a whole new world for me.@
    We have a thick layer of leaf compost and partially decomposed sticks. A McLeod is useful for moving this stuff. Especially in low-slope areas, getting the duff well off the trail corridor is important. Otherwise I end up fighting the pile as I cut down into the soil.
    I use a Stihl long-reach hedge trimmer to cut brush back from the new trail corridor. Establishing a wide corridor equals years of reduced cutting in the future, and makes it easier to get cuttings off the trail.
    The park I work in is heavily forested. Clearing a new corridor means chain saw work in addition to everything else. There are fallen logs everywhere. A big storm can drop as many as 50 logs on our trails.
    *https://www.amazon.com/s/ref=nb_sb_n...n+stone+buster
    @ I have two sets of problems to deal with regarding rocks. One type is the rocks in the tread that are poorly shaped for riding over, and are too large for me to pry up with a bar. The other is armoring streambed crossings. Fitting rocks together is always a challenge. I can, to a limited degree, shape rocks by cutting them. I can destroy rocks much more reliably than I can shape them though.
    May 2013
    In all honesty, my favorite trail tools are my gas grill and an ice cooler filled with beer. I hope this doesn't make me a bad person.
  1. Best tools for clearing baby trees
    By bank5 in forum Trail Building and Advocacy
    Last Post: 11-23-2014, 06:43 PM
  2. Trail clearing equipment
    By bald eagle in forum Pennsylvania
    Last Post: 07-26-2012, 10:33 AM
  3. Trail clearing Disciples
    By General Coonskins in forum Singlespeed
    Last Post: 11-25-2011, 11:37 AM
  4. Replies: 87
    Last Post: 07-29-2011, 02:37 PM
  5. Trail Clearing Party - Fort Drum
    By zhanx in forum New York - New Jersey
    Last Post: 07-12-2011, 06:24 PM
Members who have read this thread: 176
