Results 1 to 7 of 7
    Aug 2010
    Bridge building using a log
    I have a bridge that needs to be rebuilt since the stringers and decking is getting pretty rotten. The original bridge builder attached the stringers along the length of a larger ceder tree to provide a wider surface and then fastened the decking to the log and stringers. This makes a structurally sound bridge but it creates an area for organic material to collect up below the decking between the stringer and the log.
    My initial plan was to rebuild the bridge similar to the way it was initially built, but wanted to tap you guys first for some feedback. And yes I was to deck it rather than make a skinny.
    bridge 8.pdf
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Summit Ridge Guy View Post
    bridge 8.pdf
    Add a second log for a more conventional two stringer bridge.
    mtbtires.com
    question for the OP: is the log providing a significant amount of strength, or is it just in a convenient spot to position the stringers? If the latter, just use PT lumber and size the stringers appropriately (e.g. 2X10 or 2X12, not 2X4). If the log is structurally significant now, it certainly won't be forever.... Check in w/me via the Evergreen listserv if you'd like framing details on the bridge we built in Big Finn Hill Park 3 years ago; it has a 26-ft clear span.
    Dirt Monkey
    We built a small bridge out of a large diameter (12") oak log cut into two beams. Cut the log in half lengthwise and flattened the sides to make the decking and foundation more stable. All cut freehand using a chainsaw (even the decking). It took around 12 hrs total to build and would have gone much faster if we had a larger saw.
    Photos:
    The natrual curve of the log fits the dip it crosses.
    Bike for scale.
    Hand sawing the planks left a very rough and slip resistant texture on the decking.
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    Build it like it was before but put spacers between the log and the stringers. Small blocks of 2X?. It will hold the stringers out from the log and crap will fall through.
    Quote Originally Posted by Trail Ninja's Son
    You may be happy to hear that my dad has kicked cancer's ass. Now he's looking for whoever sent it.
    Aug 2010
    Good idea Trail Ninja. Thanks!!
    Terrain Sculptor
    You're welcome. You'll still want to use treated or rot resistant wood because the blocks will eventually rot.
    It's wood. If you get 10 years out of it, you're doing better than most.
  1. Building a pole bridge
    By RidingMyTrail in forum Trail Building and Advocacy
    Last Post: 12-12-2015, 07:46 PM
  2. Building a bike & building a computer=similarities?
    By fatcat in forum California - Socal
    Last Post: 03-31-2013, 06:23 AM
  3. Replies: 17
    Last Post: 01-15-2013, 12:58 PM
  4. The little bridge in CC
    By Hikers Only in forum California - Norcal
    Last Post: 04-05-2012, 07:28 PM
  5. New bridge at Annadel
    By GuruAtma in forum California - Norcal
    Last Post: 11-16-2011, 05:23 PM
