Results 1 to 7 of 7
    CrgCrkRyder
    Best cutting tool for briars?
    Ideas on the best tool for clipping back briars. The clippers I use for mountain laurel and limbs seem overkill for briars and probably don't cut them all that well either. Ideally something small & light that you could throw in the camelback. Ideas?
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    machete? Weedwhipper? Let the horses snag off the thorns?
    Seriously, just rip the fvckers out of the ground. They serve no purpose along the side of a trail. best be gone with them.
    Just a regular guy.
    Masher
    Actually ripping them out along with the roots is the only solution - the plants send off runners that emerge nearby and form another 'stalk'... cut them off at ground level and they will re-emerge someplace else. I think you have to pull the roots (and you'll still miss some and they keep coming back).
    Ride Responsibly
    Reputation: LWright's Avatar
    how about a goat? at least you would not get chit for having a dog on a trail!
    Reputation: wonky57's Avatar
    Karl Childers says some folks call it a sling blade. It's not small or light but works. Uh huh.
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    How about a small pair of bypass pruners so that you can get close enough, and then a Pulaski to cut the roots out?
    I have heard that Napalm works well also....
    CrgCrkRyder
    Quote Originally Posted by Francis Buxton
    I love the smell of Napalm in the morning.
    A swingblade, a goat, Napalm, a pulaski, and some really heavy gloves. Won't I be a site riding down the trail. May try a pair of those bypass pruners - even if it is only a temporary solution. Sounds like total war against briars is the only real longterm solution. Sort of like Kudzu. Thanks to all for their ideas.
