Results 1 to 2 of 2
    Aug 2005
    When to use lithium grease.......
    My Yeti 303RDH requires white lithium grease for its rail system, so I picked up a tube of that recently. But I've been using Phil Wood grease forever on my bike for almost all threads and anywhere there is metal to metal contact. So my question is, what's the difference between the two? What applications are either designed for? Just curious.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    Plays with tools
    Reputation: customfab's Avatar
    You can use the white lithium anywhere you've used Phil's in the past. Although I would recommend anti-seize any time you're bolting dissimilar metals together, which is fairly common on bicycles.
  1. Replies: 2
    Last Post: 09-25-2012, 12:04 PM
  2. White Lithium Grease for Shift Levers
    By w201 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2012, 08:47 PM
  3. Lithium Air Batteries
    By syadasti in forum Lights DIY - Do It Yourself
    Last Post: 01-13-2012, 02:04 AM
  4. Lithium Imide
    By slcpunk in forum Lights DIY - Do It Yourself
    Last Post: 07-29-2011, 02:09 AM
