Results 1 to 10 of 10
    Reputation: Wankel7's Avatar
    What tool to remove this freehub?
    Freehub on my Diamondback Insight (City bike with 700 c wheels) bike isn't freehubbing like it should. It is an 8 speed hub and should be Shimano butI don't see any parts number.
    Googling says a 10mm hex should do it but that is too small and a 12 mm is too big....don't have access to an 11mm.
    http://db.tt/Z4FCTj2c
    looking at the freehub
    http://db.tt/17CCQA6b
    looking down into the freehub
    They are dropbox links
    Reputation: bvibert's Avatar
    Mar 2006
    According to Park some brands use an 11mm hex wrench.
    Park Tool Co. ParkTool Blog Freehub Service
    Thank you!
    May 2014
    hey, did the 11mm hex worked for you? i cant get mine off even with 24" breaker bar
    I ended up not needing to replace it. If you are using a 24" breaker bar and it isn't striping it out I would assume you have the right tool in the hub?
    May 2014
    Yes, 11mm should be the right tool, but I am not entirely sure about me standing on the 24in bar and not moving the bolt at all, gonna visit performance later this week...
    Mar 2006
    Instead of standing on it, try hitting the wrench with a big hammer. The impact should help break it loose. Make sure you're holding the wrench firmly in the freehub so it doesn't start backing out and strip the head.
    Reputation: IRONMAN1518's Avatar
    Don't forget that when re-installing the freehub use some grease (or better yet "neversieze" on the bolt threads and tighten the bolt to the freehub to the correct torque.
    Torque Specifications - Bicycle Tutor
    After you take the freehub off the hub, you can pry out the rubber seal on the bottom, and using a pars washer or solvent you can flush out old grease, dirt, etc out of the freehub. After that I blow the solvent out with an airline, then have used several methods to grease/oil the tiny ball bearings inside the freehub. Have used 30 motor oil by holding the freehub upside down and pouring the oil thru the bottom of the freehub. (before I put the rubber seal back on).
    Park Tools has a picture service story to show what I'm talking about.
    I've also used a Moringstar freehub greasing tool, but I believe the company is no longer in business. {Please correct me if I am wrong}. He made a neat tool that fit inside the top end of the freehub, and he made a real slick thin grease that you could inject into the freehub. Freehub Buddy / Morningstar Tools
    IF you are REAL "nerdy/OCD" you can make a removal tool out of 1/8" thick plate and you can unscrew the inside top of the freehub. {NOTE it is a "backwards" thread, i.e. a "left hand thread". } You leave the freehub in the wheel, gently pry out the top/end seal (without destroying it), so you can put the "plate" you manufactured, and using a long cresent to turn the plate and hold the plate down with your other hand unscrew it. NOTE: follow my suggestions at your OWN risk. If you decide to open up your freehub a million little bearings will come out along with the pawls inside. Ok not a million but like 50 1/8" ball bearings.
    Winterizing Your Freehub
    Training on Hills Builds Character, That's How I Got To Be One!
    Use IMPACT FTW!
    Reputation: hartwerks's Avatar
    Oct 2011
    Morningstar is very definitely out of business. The very sad story here:
    http://reviews.mtbr.com/toolmaker-pa...alifornia-home
  1. Remove freehub on redline monocog?
    By airic81 in forum Singlespeed
    Last Post: 10-18-2012, 12:46 PM
  2. How do I remove the freehub sealring from a Hadley?
    By Jon Richard in forum Singlespeed
    Last Post: 06-27-2012, 06:46 PM
  3. Which tool do I need to remove BB on my HiFi?
    By quikcolin in forum 29er Components
    Last Post: 06-03-2012, 07:07 AM
  4. Take Along Tool to Remove non-QR Wheels
    By William_Cannon in forum Tooltime
    Last Post: 10-03-2011, 08:08 AM
  5. Remove dustcap & seal from XT freehub????
    By skankingbiker in forum Wheels and Tires
    Last Post: 04-09-2011, 08:50 AM
