I'm curious what kind of tools you guys use from non bike companies. Things like screw drivers, diagonal cutters (aka dykes), adjustable wrenches and the like. I've got a hard sided travel case that has a pretty complete set of tools, but there are very few tools from bike companies in it. Pretty much the stuff that is truly bike specific; BB socket, chain tool, lock ring tool, chain whip and so on.
- Benchmade knife have been a good multipurpose tool. (Only used it on the bike once making a boot out of old trash on the side of the trail repairing a tire.
- GB mini hatchet perfect tool for around camp.
- Old British inclometer measuring angles very accurately for a bike frame, vehicle drivelines or what ever else needs a little precision.
- Old Snow Peak gas lantern. (self explanatory for around camp)
- Sherline Mill & lathe making parts & tools as needed
I just got a set of Bondhus hex and Torx wrenches. I got the sets of longer loose keys. It seems like every job on a bike involves torquing some size of hex or star bolt. It's so much easier to work with the individual wrenches than the foldup sets. They have a grippy matte finish, and they're made in the USA. I also have an older set of Craftsman torx drivers, with the screwdriver handles. I'm not sure if they are still available, but that T25 torx driver saved a lot of time when I was swapping out my brake rotors last month.
Justin
Salt Lake City 2012 Specialized Stumpjumper FSR Comp 29
2006 Specialized Allez Expert Double
I cary a leatherman supertool200 everywhere I go. I am an industrial mechanic, I have a pretty full kit of snap on tools. For bike rides I bring along 1/5 and 3/8 torque wrenches and sockets for every bolt on the bike. And 6 and 8 inch adjustable wrenches.
I use Craftsman Metric T-Through Handle Ball End Hex Key wrenches. The ones with the ball end on the long side and the standard end on the handle. I keep the 4,5,6 on the tool tray, I like them better than using a triple wrench.
knipex pliers wrench in 7in and 10in. 1/4 dr roto ratchet(mine is gearwrench brand but other people make them. harbor freight if u want cheapo to try it) and a 5mm bit from snap on. i am not too picky on screwdrivers just need good tips, mine are craftsman pro for ease of warranty. usually replace #2 once a yr
Pipe cutter - for trimming down steerer tubes, handlebars, and seatposts
Electrical tape - for wrapping brake and shifter lines together for a clean look
Fabric measuring tape - for measuring various things and cockpit setup
Round file - debur things after cutting
I used to use a nice Ridgid pipe cutter for steerer tubes but I've moved away from that (just a hacksaw and the park cutting guide). The pipe cutter always seemed to slightly deform the very end of tube so that it was hard to get things to slide onto the tube (stems, etc).
They usually roll a little bead of metal at the cut line preventing good fit at first. 10 seconds with some high grit sandpaper takes that right off. Just hated the idea of buying a cutting guide that I'll really only ever use for bike stuff.
I'm so glad I've got a horizontal band saw to cut steer tubes with. That's not why I bought it but man is it handy.
I love my swivel reamer for cleaning up cut steerer tubes(inside), or any tubes for that matter. I originally bought it for cleaning up exhaust pipe, there's nothing better than finding other uses for tools. (especially when it's bike related)
I have many tools from various mfg's but the ones that have always seem to save day are the medical ones...
dental picks-clean stuff-an assortment on angles
forceps-retrieve things-an assortment of lengths and tips
stethoscope-pin point that creak and knock
