Results 1 to 6 of 6
    What size cone wrench for Shimano XT M756 Disc hubset?
    Anyone know this off hand? the rear is the one I am most concerned with.... but if someone knows both that would be great....
    Thanks in advance...
    nobody knows???? The rewiews say the cones need to be tightened often, so someone must know.... lol
    to the top
    You'll need a 15 and a 16mm
    here ya go
    Quote Originally Posted by shale
    here ya go
    I already got the right ones... but thanks...
    Reputation: Ottoreni's Avatar
    Wanted to confirm...size
    Is it the 15mm and 16mm?
    I will need two sets. One for each side of the hub?
    My 756 disc hub is loose on the driveside. Need to tighten it.
    You cannot go against nature, because when you do, its part of nature too.
