Results 1 to 3 of 3
    What do indeed to get this crank off?
    I have a 2008 trek fuel ex8...with LX cranks. I don't see any markings to tell me what crank type it is therefore I'm a bit confused as to how to remove it. I do believe it has the external bearing BB. Below is a picture of what I need to remove (I assume) - the black "star" bolt on the non drive side. I've looked on park tools site but am not seeing anything.
    Attachment 730569
    Just figured it out...a shimano TL-FC16
    Plays with tools
    Reputation: customfab's Avatar
    Once you loosen the pinch bolts you can normally get the black 'adjuster' out with a pair of needle nose or snap ring pliers in a pinch. Their only supposed to be finger tight.
