Results 1 to 8 of 8
    Tubeless Question
    When using a tubeless type Stan's valve stem with Stan's fluid, how tight should the valve stem nut be? Normally for tube, I hand tighten just enough so it doesn't rattle but I know the tubeless stem has to seat on the inside of the rim.
    Reputation: pablobell's Avatar
    Oct 2013
    As tight as you can easily get it with your fingers.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Yup, just your fingers should suffice. Give the valve a bit of a push from the outside if you feel like it: it makes the stem nut a bit easier to rotate.
    Just stay away from tools of any kind!
    Sorry to bring up and old post but I had an issue just this Saturday with a finger tight core, it unscrewed with the dust cap when I double checked pressures before my ride. I gave it about a 1/4 turn past finger tight with some pliers I had with me and tested by taking the cap on and off a few times and it no longer came out with the cap.
    Oct 2013
    That would be annoying, another reason not to use valve caps!
    Reputation: arphaxhad's Avatar
    I have one of those old school spoke nipple wrenches that I use to tighten the core.
    Tubeless Question-bicycle-6-way-font-b-spoke-b-font-font-b-nipple-b-font-key-bike-cycling.jpg
    I hold the body with my fingers as I do to keep it from rotating. If it was that loose that taking the valve stem cap off, it was too loose.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    Tubeless Question
    You can just use a valve core removal tool costs 8 or so bucks. Jenson has them.
    http://m.jensonusa.com/Stans-Notubes-Valve-Core-Remover
    Sent from my iPhone using Tapatalkb b hm
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Yeah, get a valve core tool...using yer teeth can be a little difficult sometimes.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Tubeless question
    By tom34 in forum Knolly
    Last Post: 07-18-2013, 10:27 AM
  2. Tubeless question from tubeless newb
    By johnb in forum Wheels and Tires
    Last Post: 05-13-2013, 11:25 AM
  3. Tubeless question
    By xxxxx in forum Salsa
    Last Post: 11-21-2012, 09:11 PM
  4. Going tubeless question
    By LvilleFan in forum General Discussion
    Last Post: 08-13-2012, 04:23 PM
  5. tubeless question
    By dundundata in forum Specialized
    Last Post: 09-20-2011, 11:19 AM
