Results 1 to 5 of 5
    tripple to dubble
    I'm changing my crankset from a tripple to a dubble with a bashgaurd.
    I'm using my old granny and middle crank but when I put them togetter they hit. What have I done wrong or what am I missing??
    tripple to dubble-dsc_0544.jpgtripple to dubble-dsc_0550.jpgtripple to dubble-dsc_0554.jpg
    Reputation: bvibert's Avatar
    Mar 2006
    Looks like your bashguard is mounted between your "middle" ring and the spider, it should be on the outside of the spider, where the big ring would have been. That cutout in the bash guard is meant to line up with the crank arm.
    Reputation: gmats's Avatar
    Apr 2005
    For some reason (don't know if it is just the images) it looks like you have the bashguard mounted between the "bigger" ring and the spider. That would unintentionally space the too far toward the middle of the bike. Bashguard is suppose to mount in place of the outer, big-ring that you removed. The middle (now your large ring) should be bolted to the inner side of the spider. Also, it looks like the bolts are backward - the allen key heads should be facing the outside. Finally, like bvibert said above, that big cut-out (hole) is suppose to line up with your right side crank arm.
    Good luck with that, hope it all works out.
    Ok thank you, stupid me for making that mistake.
    Apr 2005
    Quote Originally Posted by kurrefromtungere View Post
    Nah, not stupid. It happens and it's how we all learn. I've certainly had my own share of "DOH!" moments. The difference is you were smart enough to ask for help, I sat there and often banged my head until I figured it out.
  1. Tripple XM-L
    By Goldigger in forum Lights DIY - Do It Yourself
    Last Post: 04-12-2013, 05:53 PM
  2. Another Cute Tripple XML
    Last Post: 04-17-2012, 01:42 AM
  3. Tripple XM-L with 3W rear Red LED
    By Captain_S in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2012, 09:43 PM
  4. Tripple Threat
    By modifier in forum Singlespeed
    Last Post: 10-15-2011, 06:35 AM
  5. Tripple XML
    Last Post: 06-10-2011, 12:18 PM
