Results 1 to 15 of 15
    Reputation: Mithrandir's Avatar
    Tool to remove the RaceFace Turbine BB on the Nomad3
    Hi guys,
    Do you know what is the tool to remove the RaceFace Turbine BB on the Nomad3? Yesterday I tried a Shimano 32mm and was too small, however the BB says "Cinch 30mm" on the side o_O
    Also tried the one for the press fit BBs and was a closer fit, but also didn't worked.
    A bit lost on what to look.
    Jul 2014
    park tools bbt-79 should work
    BBT-79 Bottom Bracket Tool | Park Tool
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Yep, you've got a 12-notch, external bearing.
    Tool of choice.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    RaceFace page says:
    Custom CNC tool interface shaves weight while ensuring positive engagement with standard Shimano and Park tools.
    Not sure what you mean by " I tried a Shimano 32mm" and "Also tried the one for the press fit BBs"? No idea what tool you might be trying to describe but can't imagine how any of them would look like they would fit an external bearing system.
    Boy, that Abbey tool is gorgeous.
    since 4/10/2009
    Reputation: Harold's Avatar
    The CINCH BSA bb needs a specific tool. It is not the same as Shimano's. In addition to the Abbey tool shown above, these will do the job.
    Race Face Cinch Bottom Bracket Tool Wrench
    Zipp - Speed Weaponry | Accessories | Accessories | Vuma BB Wrench
    So either Op must be wrong, it's not a Turbine BB or RaceFace's product page is.
    Magically Delicious
    I saw this Park Tool:
    The BBT-19 is a heavy duty, shop quality tool for installing and removing Shimano, Truvativ GXP, Race Face, FSA and Campagnolo 16-notch external bearing bottom bracket cups.
    Magically Delicious
    I thought all Raceface BB's were 12 notch BB's. Live and learn
    since 4/10/2009
    Quote Originally Posted by Slash5 View Post
    Neither. OP Specifically said that the BB says "CINCH 30mm" on it. You were likely looking at the Turbine X-Type BB, which DOES use the same interface as Shimano bb's.
    CINCH BSA bb's use a different tool (AFAIK, ALL BSA 30 bb's use different tools). Current Nomads have SRAM cranks/bb's, so they're not necessarily helpful to answer the OP's question. If it's similarly spec'd to this 2015 Nomad, which has a RF SixC crank, that explains the use of a CINCH BB, because that crank has a 30mm spindle, not the 24mm spindle of the x-type bb's.
    https://www.santacruzbicycles.com/en...ives/frame/565
    Quote Originally Posted by Mithrandir View Post
    Ops specifically said RaceFace Turbine BB.
    since 4/10/2009
    Is this an argument you really think is worthwhile?
    Magically Delicious
    Ok, here's the bottom line for the OP...
    If it is a 16 notch external BB, then it has a 24mm spindle and it can use a Shimano BB tool.
    If it is a 12 notch External BB, then it has a 30mm spindle and can not use a Shimano BB tool.
    Thanks for your feedback!
    I'm certain the BB says "Cinch 30mm", it seems BBT-79 or similar is the way to go.
    BTW, the Nomad is model 2016, XO1 kit and RaceFace Turbine cranks.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by Cleared2land View Post
    That is an outdated descreption from the days when the 16 notch pattern was the only one. This predates all of the 30mm spindle options from various manufactures.
    30mm spindle Cinch BB's are 12 notch, the older 24mm spindle BB's are 16 notch
    A word about oversized threaded bottom brackets, it's confusing as all hell. There are no fewer than 8 different tool patterns for this single style of bottom bracket. They absolutely could all be the same but when you've got a bunch of small to mid sized companies making the parts corporation isn't something that happens easily.
    otb club member
    Reputation: Chris2fur's Avatar
    Quote Originally Posted by Harold View Post
    OK, really feeling left out here...
    RWC Exteral BB30 Cup Tool by Real World Cycling
  1. Raceface Turbine 2x crankset $75!
    By cameden in forum Classifieds
    Last Post: 06-27-2016, 06:40 AM
  2. Replies: 19
    Last Post: 01-20-2016, 05:43 AM
  3. How to remove RaceFace Turbine crank?
    By Pocket Lint in forum Tooltime
    Last Post: 10-14-2014, 10:02 AM
  4. How to remove raceface turbine
    By rave81 in forum Tooltime
    Last Post: 08-18-2014, 09:45 PM
  5. RaceFace Deus, RaceFace Turbine vs Easton EA90?
    By kaushama in forum 29er Components
    Last Post: 09-18-2012, 08:03 PM
Members who have read this thread: 26
