Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Tire levers?
    Reputation: Hoban's Avatar
    Oct 2012
    Tire levers?
    My little blue park levers met their match yesterday, and would like a more robust set. The wire bead Nevegal was a bastard to get off my Sunringle wheel.
    Longer, and made of aluminum I'm thinking. I like the look of the crank brothers tool.
    Any recommendations?
    pedros are the heat. good technique helps a lot. break the bead and push it into the drop center of the rim
    Jan 2011
    REI's Novara levers are surprisingly robust. And cheap, which is key when it comes to tire levers.
    I've broken the blue park ones, as well (with proper technique). Will never get them again.
    My garage is a revolving door of bikes, wheelsets, & frames
    www.mtbdeals.com
    Nov 2012
    I just use my motorbike tyre levers.
    WAY easier. Just gotta be gentle.
    Jan 2013
    I got to find a nice set of metal levers... I always snap the plastic ones.
    Well...nicest steel core I've use is PDW's coated 3wrencho. It's expensive at ~$15USD each.
    Park makes good steel levers that aren't too expensive for a pair. They do need a bit of care to use without damaging rims, but are otherwise no different from a [long] plastic lever.
    Minoura makes forged aluminum levers that come in a three pack that aren't bad at all.
    All that said, however, the best bang for your buck will be Pedro's plastic levers. With good technique, you will not break them, and they come with a lifetime warranty. I've never found a tire they didn't remove.
    Crank Brothers speedier lever is nice.
    They are now my favorite lever for mounting stubborn tubeless tires
    Quote Originally Posted by reptilezs View Post
    Another vote for petros. probaby have busted a dozen levers over the years especially on UST tires but these petros milk crates have been going strong for a long time. They are plastic and wide so i never feel like i could damage the rim or tire with them.
    Plays with tools
    Reputation: customfab's Avatar
    Park does some steel cored plastic covered tire levers. I think Leyzene might as well.
    I like the pedros ones as well. But they still break from time to time. Or get lost.
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by Ratt View Post
    me too.. been thru a few diff ones and finally got them as a freebee add on back in like 2006 or 7 and have gone and gotten another set ..one set in the box, one in the van. Use them pretty regular and take WAY more than the Parks ever had!! I do use the shorter yellow ones.. been more than enough for any tire they have ever gone against
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Quick Stick
    I've always liked Quick Sticks. I've never had to worry about pinching a tube.
    One Gear
    Reputation: .40AET's Avatar
    +1 for Quick Stick. Been using them for 15 years and never met a tire that it couldn't handle.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Pedros' are my favorite. They're strong enough for any tire without being able to cause damage like a metal lever can. If you're using dual ply wire bead DH tires, you might have a case for metal levers; for everyone else those Pedros' levers are where it's at.
    ready to ride
    Reputation: mattnmtns's Avatar
    The Jensonusa house brand are pretty good too. Seems more durable than the parks. Seems like a good value @ $2.99 for 3. Had mine about 6 months, been using them a good amount changing tires seem to be holding strong.
    Sent via my heady vibes from the heart of Pisgahstan
    Dec 2010
    My vote is for Pedro's. The plastic coated, steel core'd Park ones aren't so great. I've used a couple pair and the plastic always chips off after a few tight beads and you're just left with the steel core. I won't use the blue plastic Park levers because they're garbage.
    No matter how slow you ride, you're faster than anyone sitting online whining about slow riders.
    May 2012
    I've had great luck with Avenir metal-reinforced levers.
    Wanderer
    Reputation: Toff's Avatar
    Sep 2004
    I've got an old pair (10+ years old I guess) of the park blue ones and without a doubt they are stronger than the new park blue ones.
    They see me rolling.
    Jan 2013
    Park TL-5
    I have had plenty of plastic tire levers break on me, so I went with the Park TL-5 set. They are absolutely fantastic and will remove any tire without fuss. However, they can scratch the finish of the rim. I was going to start a new topic about this because I searched and found nothing but then discovered that members with less than five posts may not start a topic. Anywho, does anyone have any way of preventing rim damage with these levers? I am thinking of coating them in plastidip, which hopefully should solve the problem. Any thoughts?
    Plastidip works fine, but so will good technique. I use other levers in combination with the large steel Park levers, as they don't have hooks (which makes not scratching the rim very hard).
    Jan 2013
    Quote Originally Posted by wschruba View Post
    Thanks! Admittedly my technique probably could be better!
    Oct 2012
    Got a couple of the small plastic Pedro ones. Seems much better, but I also haven't tried to take off that damn Nevegal either. IT seems these Sunringle rims are a little taller than others I've had.
    MTBR ProReviewer
    Reputation: pastajet's Avatar
    Prestacycle’s Prestalevers - only lever I have never broken
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    I got a pair of generic green levers from Performance several years back.....only set of levers I have not broken.....and I have used a lot of them over the years working in a shop.
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Well, since nobody mentioned these...
    Specialized Prybaby levers. I've got several sets, thin & strong, but hard to find. Caveat - I' have broken 1 of them.
    JMJ
    Reputation: breckenridge's Avatar
    +another for the Quik Stik. That's all we used at the shop I wrenched at for 8 years. They don't pinch and last forever. Long-ish for good leverage too.
Hot Deals
Contests
Latest Mountain Bike Articles
