need a little help here...
i need to pull a brake stud out of an easton ec70 carbon fork, in order to adjust the positioning of the pin plate behind it. having some problems though. i have pulled the fork from the frame, tried tapping it with a metal object, mild heat with a soldering iron, and some light use of a bench vise, to no avail. i'm a little leary of pouring on the heat, as i'm afraid the bond between the cf and the threaded insert will let loose before the brake stud will. any body know if pb blaster plays nice with carbon?
