Results 1 to 8 of 8
    May 2012
    Stripped allen key
    So I was trying to take the screws off the adjusters on my 888 so i could get to the internals. They're making a knocking noise during the first inch of compression. most likely a spring issue. ANYHOW, both screws have the heads stripped out and i can't get anything to grip. I've tried hammering a torx into it but to no avail. I don't have a dremel and they look like they are too recessed for that to work anyhow. The last thing I can think of is to jb weld an allen key/torx into the hole and get them out that way. Anyone have any other ideas?
    Oct 2012
    Yes. They make screw/bolt removers for this; they work well.
    The two other things that have served me well are: Jam a Torx bit in (which you said didn't work), and get a left-handed drill bit and (gently) run it in with the drill in reverse.
    get a tool called a "sock it out" or you can drill and ez out
    Reputation: elcaro1101's Avatar
    Jul 2013
    Search google for "ez out" or your local hardware store should have something similar. Also referred to as an extractor
    Reputation: squareback's Avatar
    If you are going to try and drill before putting and extractor in, without a doubt use a left-hand drill.
    PS. Those bolts may have been loctited. You can use a high wattage soldering pencil to get in there (or a woodburning craft tool). You will know that you got it hot enough when you catch a whiff that sweet loctite smell.
    tagged
    roccowt.
    rocnbikemeld
    Do yourself a favor and find a local machine shop and take it there. They'll do it correctly and you will probably be happier in the long run.
  1. Stripped allen bolt!!!! HELP
    By ingregrity in forum Singlespeed
    Last Post: 07-24-2015, 07:57 AM
  2. stripped out allen key
    By RickBerg in forum General Discussion
    Last Post: 08-31-2013, 07:02 PM
  3. Allen/Hex screwdriver bits?
    By JR 137 in forum Tooltime
    Last Post: 08-24-2012, 02:42 AM
  4. allen wrenches
    By davis119 in forum General Discussion
    Last Post: 07-20-2012, 02:34 PM
  5. Yakima q tower allen head stripped
    By Litemike in forum Cars and Bike Racks
    Last Post: 04-23-2012, 11:07 AM
