Results 1 to 16 of 16
    Reputation: big_mountain_biker's Avatar
    Spin Doctor Pro G3 or Park PCS-10 Workstand?
    I have a bunch of performance points to spend so I wanted to get a workstand..
    These are the two I'm considering:
    http://www.performancebike.com/shop/....cfm?SKU=19982
    and
    http://www.performancebike.com/shop/...tegory_ID=4216
    Which one looks like a better bet?
    I like the Park. Clamp. . .and the ability to turn your bike at dif. angles. That my 2 cents.
    dirty trail dog
    Reputation: Rebus's Avatar
    I had the same bike stand delimma. I compared these same two stands. I picked the PCS-10 and I love the thing. The clamp is awesome. It felt a lot more solid and durable than the Spin-Doctor. Maybe not quite as easy to use, but better made.
    yep...
    I have the Spin Doctor. It will angle bike, and I prefer the adjustable tripod legs for stability.
    My buddy has the Spin Doctor one and the only thing I don't like about it is that the little wheel that is used to clamp has to be spun all the way to where you want it, where as the Ultimate stand that it is obviously modeled after only needs to be loosened and then slides or slides closed and just needs to be tightened.
    Did that make sense?
    I would go with the Park.
    If you get the Park, you better make sure that you maintain it. Keep that clamp mechanism clean and lubed. I had one like that, hated it. Have a stand with a clamp like the spin doctor, much nicer.
    Really you want 2 stands, a general 'clamper' that your looking at, then another that will lock on to the fork.
    spin doctor is a bit more stable and folds up easier, but certain plastic parts are apt to break. however, spin doctor means you are buying from performance, and they have a 100% satisfaction guarantee, even if you decide you don't like the way the stand paint is fading 12 years down the road.
    Let's ride
    Reputation: rensho's Avatar
    The G3 is a good stand. The rotation mechanism could be better.
    I have the G3, but wished I bought the Ultimate stand.
    a.k.a. BicycleKicks
    Reputation: 40hills's Avatar
    I have the Pro G3. It's a great stand and I am totally satisfied with it. It folds up quickly for travel and is very solid when set up. As mentioned already, coming from Performance you can get a refund if you don't like it. I'd bet you'd like it enough to keep it though.
    I read that on the internet.
    New question here.
    Quote Originally Posted by Rebus
    I compared these same two stands. I picked the PCS-10 and I love the thing. It felt a lot more solid and durable than the Spin-Doctor. Maybe not quite as easy to use, but better made.
    Hi.
    I've narrowed my search for a stand down to these two also. I see the Spin Doctor is aluminum. Would it be fair to say that it's biggest advantage is easier portability?
    Sturdiness is a bigger issue for me than portability, as I don't plan on taking the stand anywhere.
    Ease of setup is important to me too, though. I want to be able to set up the stand and put it away with a minimum of fuss for quick tire changes or minor adjustments.
    offroader
    Dec 2008
    I own the G3 it's a great stand. The only other stand I would consider over this one is the Ultimate.
    Quote Originally Posted by dr.wierd
    Glad to hear that tip about the Park stand. I have one- haven't used it yet. Thanks for the tip!
    roccowt.
    rocnbikemeld
    One Gear
    Reputation: .40AET's Avatar
    I looked at the same 2 stands and the Ultimate last year. Performance put it on sale and then ran 20% on Thanksgiving night on the G3. That sealed the deal and I've been very happy with it. The tripod legs on the G3 are huge and make it very stable.
    Nov 2008
    I have the g3 and have used the park stand. I think that the park clamp is a little nicer but not much, the g3 is portable and the base is much more stable. I also like that the g3 is height adjustable so if you are working on the drivetrain then you can raise the bike up and if you are working on handle bars you can lower the bike down.
    Spin Doctor Pro G3 Work Stand $99 w/free shipping 24 hrs
    Can't beat this one with a stick!
    I have the PCS-10 myself. Will get the work done and it is also height adjustable.
Members who have read this thread: 7
