Results 1 to 10 of 10
    Jun 2013
    So, uhh...What's in Your Toolbox?
    Hello. I wanna know what you keep in your toolbox. In fact, I wanna know what the box itself is, too. I'm looking to put one together that I can have around the house and keep in the car for group rides, etc. I'd like to have some ideas from you folks. Begin ^_^.
    Tackle box with a tray works very well. The size is up to you.
    Jun 2013
    Quote Originally Posted by the-one1 View Post
    Cool. And what do you consider to be the essentials that you keep within?
    Plays with tools
    Reputation: customfab's Avatar
    two small parts boxes, one for road other for MTB.
    two sets of allen wrenches, one L and the other P
    torx wrenches T7-30
    Wire rope cutters for housing and cable
    side cutters
    Knipex alligator pliers
    cone wrenches
    flare nut wrenches 8-11mm double ended
    pedal wrench
    modular bearing press
    Hanger Alignment Gauge
    Torque wrenches, one for small stuff another for BB's and cranks, along with sockets
    flashlight
    screwdrivers
    poker
    chain tool
    spare chain
    ratchet 1/4"
    chainring bolt tool
    BB tool for OBD, screw square taper and ISIS they should get with this decade.
    3 small sets of pliers for different things
    master link removal tool
    Custom 15mm allen for Shimano freehub bodies.
    That's about it, off hand anyway. I keep it all in a Chicago case that's got pockets for everything and makes working out of it about the same as having everything on a pegboard in a shop. Definitely overkill for being a good riding buddy but I pick up the pieces when that guy can't deliver.
    old vid of my tools and work supplied tool box. i have a pelican case but i need to figure out a way to mount organizers or palettes in them. i don't want to spend a lot on palettes because i got the case for free
    MTBR Member
    Reputation: ncfisherman's Avatar
    That's quite the carry case, Customfab...ultimate riding buddy. That just about covers it and some. I have a lot of the things listed and bring along my spare park truing stand for trips.
    Always good to have spare parts on hand for the car kit as well.
    Jun 2013
    And if you tool folks were going to buy a new toolbox or bag to put all your treasures in now, and with some portability in mind, which would it be for you?
    I'm looking on Amazon.com right now and they have an enormous amount of them. Some of the bag-style ones look amazing, especially for putting in the car. Example:
    Custom LeatherCraft 1539 18 Multi-Compartment Tool Carrier - Amazon.com
    I want to know your opinions! Thanks for your help.
    Plays with tools
Size:  45.5 KBI run something like this with a winged pallet. Bags aren't bad but they don't hold up well on the airplane, something that's fairly important to me.
    Reputation: repoman's Avatar
    I keep my tools well organized in a fairly large plastic toolbox I bought at Home Depot. My tool set has built up over the years with tools and parts that work for the bikes and components I've owned. I add more tools as I learn how to do more advanced repairs. This kit travels well and has what I need almost every time.
    Pedal wrench
    Chain whip
    Allen wrench set
    Crank remover
    Bottom bracket tool
    chain tool
    shock pump
    Torque wrench
    pliers adjustable and needle nose
    various lockring, bottom bracket, freewheel keys - Shimano stuff, octalink, XT
    big adjustable wrench
    Tubeless measuring cups and injector
    Chainlink pliers
    Cable cutters
    Screwdrivers (phillips and flat heads)
    Pocket knife
    Headset wrenches
    set of Spoke wrenches
    Electrical tape
    Zip ties
    Locktite
    Patch kit
    Spare multitool
    spares and repairs:
    tubes
    brake pads
    tubeless valve stems
    cyclecomputer batteries
    computer sensors, mounts, magnet.
    Cable ferrules
    Magic links
    Headset and bottom bracket spacers
    Jun 2013
    I use the tool box that came with my park pro tool kit.
  1. what's this thing I found in my toolbox
    By El_Bendejo in forum Wheels and Tires
    Last Post: 02-11-2013, 01:35 PM
  2. Where do I get this toolbox
    By smoothmove in forum Tooltime
    Last Post: 08-30-2011, 06:41 PM
  3. So I got a huge toolbox
    By appleSSeed in forum Passion
    Last Post: 01-29-2011, 07:01 PM
  4. Check toolbox
    By kustomz in forum 29er Bikes
    Last Post: 01-04-2011, 12:27 PM
