    Reputation: StJoeRider's Avatar
    May 2013
    Shimano Shadow rear derailleur question
    I read to turn off the shadow lever when replacing a chain.
    Well I replaced my wore out chain this weekend and after
    I did I realized I left shadow turned on. Did I screw
    something up by chance?
    BTW, how often do you maintain that little clutch box anyway?
    Mine hasn't seen wet and muddy conditions, and it's almost a
    year old.
    Thanks.
    MTBR Member
    Reputation: ncfisherman's Avatar
    I highly doubt that you messed anything up. It's just easier to replace the chain with the clutch off.
    I've only had my shadow plus derailleurs for a few months, so I haven't done any maintenance. It's fairly well sealed with a rubber seal between the cover cap and derailleur. Just checked mine out and it's clean inside, with just a light layer of white lithium grease. At some point, I might add some fresh grease, but it looks like that will be a while.
    May 2013
    This is good to know. Thanks!
    Nah, you didn't hurt anything.
    Haven't had mine long either. As NCFisherman says, just add a little white lithium grease once in a while, and you will need to tighten the friction band eventually. There is a little adjustment bolt. People use pliers, but you really should have a 5.5mm open-end ignition wrench (I got a set of Craftsman Midget wrenches off eBay). 7/32" is pretty close.
  1. Shimano Shadow Plus Rear Derailleur - Adjust with switch on or off?
    By parkp81 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2013, 04:13 PM
  2. Shimano Shadow Derailleur Hanger
    By Eric Malcolm in forum Frame Building
    Last Post: 09-15-2012, 03:07 AM
  3. XT Shadow Plus rear derailleur question
    By FireSpitter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2012, 10:35 PM
  4. Shimano SLX Shadow derailleur question
    By Sneekeemt in forum General Discussion
    Last Post: 06-28-2012, 04:22 AM
  5. xt shadow or xtr shadow rear derailleur
    By scoholofo in forum All Mountain
    Last Post: 01-11-2012, 04:49 AM
