    Gimme free stuff
    Reputation: tims5377's Avatar
    Oct 2010
    rotor rubbing on standoff
    Question for you guys: I was setting up my brakes for the first time today. I have bb7s on a Misfit dissent with the Misfit rigid fork. Im going through the setup instructions on park tool website (google will find it). I tighten the pads on the rotor to set the caliper location. when i back the pads off the rotor rubs on the caliper mounting bracket (20mm offset thingy). Anyone else have this problem? The rears set up just fine...
    It rubs enough to limit the free-spin of the wheel. The frame was painted aftermarket so It could have ~.5mm being taken up by paint. Not sure if that should matter that much though
    180mm rotor, XT hubs
    Guerrilla Gravity BAMF
    Reputation: jrastories's Avatar
    Either use emery cloth to take the paint off the IS mounts or to go one step more pro take it into a shop and have the mount faced by the shop. That should do two things first it will make the rub stop and second it will make the set up of the break a dream. I would personally take it in to be faced to make sure it is perfect.
    Rocky Element
    My Attempt at a Blog
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    1st three things that come to mid without actually being able to look at it.
    • Wheel not set correctly,
    • tab on fork wrong
    • rotor cupped
    can't tell you how many times I get people asking my about their brake issues and all it is is the wheel getting cockeye in the fork when they tighten the quick release. when you tighten the wheel, lean over the handle bars and weight the wheel.. making sure you are press straight. when you tighten the QR lever there is a bit of toque twist that will lift the axle out of the base of the drop out. loosen the caliper before hand as it will interfere if it's misaligned.
    tab wrong on the fork.. or is it studs? either way it's very possible they were welded on incorrectly.. contact manufacturer.. getting them face as was stated above will probably fix if not too far out.
    Cupped rotors happen a lot with mechanical disc brakes. there is only one piston moving and they flex the rotor over the meet the other. over time they can often get memory and stay that way. also people "straightening" them can actually make it worse as they often time use too short a tool and end up twisting the face and arm to get a flat looking face.. but they've actually just twisted the arm of the rotor.
    Going to try and bring Trail Tire TV back. go take a look...
    B A N N E D
    Quote Originally Posted by tims5377 View Post
    BB7 Installation and Setup Guide:
  1. Avid BB7 Rotor Rubbing
    By OpenTrails in forum 29er Components
    Last Post: 06-30-2013, 12:45 PM
  2. Rotor rubbing on old wheelset
    By opiants in forum Brake Time
    Last Post: 04-19-2012, 02:23 PM
  3. rotor rubbing?????
    By eddievettelt1 in forum Brake Time
    Last Post: 05-12-2011, 07:14 PM
  4. <Help!> Rotor rubbing
    By cloud25 in forum Brake Time
    Last Post: 05-01-2011, 05:02 AM
  5. Rotor Rubbing
    By Rad Rider 415 in forum Brake Time
    Last Post: 03-23-2011, 06:21 PM
