Results 1 to 5 of 5
    This is the right headset bearing?
    Hi,
    I have a problem with the upper bearing of the headset. The bottom fits perfect but the upper bearing is smaller than the cup, and this cup seems not having enough depth. The size of the upper bearing is standard IS42: 41.8mm 45º 45º 8mm height... But, look these pics
    Reputation: tomacropod's Avatar
    Get a 7mm one or, replace the top cap with a dropped cap which will cover the gap or, ignore it.
    - joel
    Cycling is Serious Business.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    what frame is that? at first I was thinking it was an internal headset not an integrated one, but then looking at the pictures is actually looks like a it's a taper and they got the 2 cups molded backward on the frame ..?
    I deff would NOT ride it like that.. the bearing WILL shift around and wear the frame making it useless.. I'd get in contact with the seller(guessing it's a new frame from the looks)
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    your upper bearing looks like a 41mm 45x45 campy style bearing. measure the id of the frame and od of the bearing
    Mar 2013
    Is that the IP-057/56 with FSA headset? I have the same issue, but with the lower bearing.
  1. Help me with headset or retainer Bearing
    By charlythen in forum Cannondale
    Last Post: 01-04-2013, 01:02 AM
  2. Banshee headset bearing ?
    By thebronze in forum Banshee Bikes
    Last Post: 06-04-2012, 09:54 AM
  3. Roller Bearing Headset
    By asphalt_jesus in forum All Mountain
    Last Post: 04-16-2012, 08:31 PM
  4. Headset top bearing cap
    By Topper_R in forum Tooltime
    Last Post: 03-17-2012, 11:30 PM
  5. headset bearing race
    By nate. in forum Beginner's Corner
    Last Post: 01-18-2011, 10:07 PM
