Results 1 to 23 of 23
    Oct 2017
    Repair Bike Stand Rack
    Any suggestions on a good reputable BIKE repair mechanic STAND for home use?
    Not really needing an industrial caliber stand; just something ideal for garage use and to take on the road when necessary.
    Thanks for your suggestions!
    Nov 2016
    I absolutely love my Feedback Pro. Great security, love the clamp for clamping on carbon and stores small enough to fit in the front seat of a sports car.
    Sent from my SM-N950U using Tapatalk
    Oct 2017
    Quote Originally Posted by tuckerjt07 View Post
    Which specific model? I’m noticing they’re pretty pricey.
    Nov 2016
    Quote Originally Posted by FLHANDSTER View Post
    The Pro Elite. They are but they are bulletproof. The only reason I suggested it was the take on the road qualifier. I'm not aware of anything more portable. There probably is though.
    Jul 2015
    You can do 90% of basic maintenance using a cheap scorpion stand they're pretty darn stable and super cheap until you want to go for a full size stand. For full size I recommend park tool product, not as portable but it will last a lifetime.
    http://www.jensonusa.com/Feedback-Sp...n-Floor-Stand/
    http://www.jensonusa.com/Park-Tool-P...-Repair-Stand/
    Sent from my XT1585 using Tapatalk
    Nov 2016
    Quote Originally Posted by wytemike21 View Post
    The only thing I don't like about park is the clamp. The dial style clamps I actually feel safe with carbon due to the increased sensitivity.
    Jul 2015
    I have to clamp on my frame so I always have a cloth between frame and clamp
    Reputation: Mr Pig's Avatar
    If you want to transport it don't buy a Park. They are made of cast iron, or at least it feels like it, and are stupid heavy. If you want light I'd either buy a Feedback of a cheapo stand. Don't be fooled by the plastic, the cheap ones work perfectly well.
    Nov 2016
    +1 for Feedback pro elite. Great stand.
    2018 Guerrilla Gravity Trail Pistol XXL
    2016 Fuse Pro XXL 29er
    Nov 2016
    It's still not the same. Not having the lever style clamp is so nice. You still press it in snug but there's no real mechanical increase, yes it's a screw but nowhere near as extreme as a lever, to snug it up.
    I clamp on the seatpost these days. I used to typically clamp on the frame but modern frames can have very thin-walled hydro-formed tubes and I really don't trust the the clamp on them.
    Reputation: Cuyuna's Avatar
    May 2017
    If you're going to carry it around then you might want the Feedback Pro Elite. I can't envision wanting to take my repair stand on the road, so at half the price, I opted for the Park PCS9. It has a screw-down clamp and works great for me. It does fold up, so I have no particular problem in the rare event I'd want to throw it in the back of the truck, but it is heavier than the FPE at 20lbs compared to 12. The only time I ever need to fold it up, is when I want to hang it on the wall and get it out of the way. For me, the extra $130 wasn't worth the weight that I'd save given my lack of need for transportation.
    Oct 2017
    Anyone ever heard of or had any experience with the RAD stand below?
    RAD Cycle Products Pro Bicycle Adjustable Repair Stand Holds up to 66 Pounds or 30 k... https://www.amazon.com/dp/B0065PHDZE..._MyH.zbGT3MDBT
    Oct 2017
    Or how about this one?
    Bikehand Pro Mechanic Bicycle/Bike Repair Rack Stand https://www.amazon.com/dp/B00D9B7OKQ..._y7H.zbJMQC1SG
    Trail Ninja
    Reputation: Varaxis's Avatar
    For something you're going to use fairly often, I'd say save up for something higher end.
    I have a couple Bikehand tools. One I used fairly recently is their cassette lockring tool. I couldn't use my existing one, I think since it just didn't work with the hub I had. When I went to put it in, the amount of slack was surprisingly high. I could rotate it about 5 degrees, before it touched any of the lockring splines, with a little wiggle room. Left a sour taste in my mouth. I'd be worried about the kind of pressure the clamp puts on components, or how likely it is to rotate. The other tool I have from them is a chain master/quick-link tool, which I'm fine with.
    Fair warning, I'm spoiled, as my shop has Snap-On tools. I can tell the difference between Bondhus allen keys and chinese ones (ex. out of one of those $50 tool kits). Using cheap tools is likely to damage your components, stripping threads, or some other problem that will give you headaches and misery.
    I'm going to +1 on Feedback Elite. I've been using one since '09 or so, got it on sale for $200. When I plan on moving again, I'm sure I'm going to love how lightweight and compact it folds up.
    We're all on the same ship, and it's sinking.
    That is a common design of stand that's been around for years and sold under various names. It's perfectly solid and works well. The plastic clamp head will flex if you wobble a heavy bike on the stand but it won't break.
    There is another version of the same stand but with a rotating quick-release lever on the clamp. I'd find one of those, a bit more convenient and no more expensive.
    The Bike Hand stand doesn't offer enough over the RAD-type one to justify the extra. All the same parts are still made of plastic and a tray isn't worth $50. Although Park think it is ;0)
    Apr 2017
    Feedback Pro Elite. Buy once cry once.
    I have this stand. I would classify as being good for home use, and it folds up nicely for storage and is light in weight. Used it for the last three years, works well,and held my bike securely when i replaced the bottom bracket. Based on you needs this would probably be fine.
    Oct 2017
    Quote Originally Posted by Druman View Post
    Which stand do you have currently?
    Reputation: Stalkerfiveo's Avatar
    Feb 2015
    I have one of these and love it:
    Spin Doctor Pro G3 Work Stand - Performance Bike
    Folds up nicely for traveling and is very stable when set up.
    In serving the wicked, expect no reward, and be thankful if you escape injury for your pains.
    Contains no juice.
    Nov 2003
    Quote Originally Posted by Stalkerfiveo View Post
    I have this one as well. My only beef is that the legs stick way out into the room and it's easy to trip on. Other than that, it works well. I got it on sale for around $120, so keep your eyes peeled.
    The old Park stand I had, the legs were flat on the floor, but as someone pointed out, it's a heavy beast.
    "...rhetorical hyperbole..."
    Oct 2017
    Quote Originally Posted by Finch Platte View Post
    I have this one as well. My only beef is that the legs stick way out into the room and it's easy to trip on. Other than that, it works well. I got out on sale for around $120, so keep your eyes peeled.
    The legs sticking out too far has been my concern as well. Hmmmmm....
    Nov 2017
    anybody just make a maintenance stand from pipe/clamps from local hardware store?
  1. Repair Stand Mounted Wheel Truing Stand?
    By homey in forum Tooltime
    Last Post: 10-08-2016, 11:25 PM
  2. Replies: 16
    Last Post: 08-26-2014, 09:01 AM
  3. OMM Skewer rack, or weld stand offs for a rack?
    By The.Dude.Abides. in forum Bikepacking and Bike Expedition
    Last Post: 02-25-2014, 05:26 PM
  4. Repair stand for hitch Thule t2 rack
    By hanklr in forum Cars and Bike Racks
    Last Post: 09-29-2012, 10:13 AM
  5. Replies: 2
    Last Post: 05-19-2011, 10:04 AM
Members who have read this thread: 14
