Results 1 to 12 of 12
    Reputation: il sogno's Avatar
    New question here. Reattaching my chainstay guard
    Hi all,
    The chainstay guard on my 10 year old Schwinn Homegrown has become unglued. What's the best way to reattach this?
    Attached Thumbnails Attached Thumbnails Reattaching my chainstay guard-homegrown-001a.jpg
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    some double-sided foam tape
    Honestly... ahh I give up
    i have some 3m trim adhesive on my bench for grips, headbadges and chainstay protectors. comes in a big spray can. use some zip ties to clamp it down
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    I would not try to save the original protector. It did its job with pride and honor, now let it rest in peace. (Or pieces). Peel it off, clean up the old glue/stickum crap with sovlent or Goo-B-Gone, and then put on a new chainstay protector. Lots of choices for something new...lizardskin, innertube wrap, bar tape, electrical tape, rubber splicing tape, helicopter tape, etc. Or go naked and wear the scars with pride.
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    Servo tape available at your local hobby supply store.
    Quote Originally Posted by reptilezs View Post
    I'll try this.
    Quote Originally Posted by Dad Man Walking View Post
    I'll keep this in mind.
    Hi.
    Reputation: jtmartino's Avatar
    Quote Originally Posted by il sogno View Post
    The only reason you should remove that original CS protector is to keep it away from harm. Those are rare and may be relatively valuable someday, given the high value of Homegrowns in general.
    Other than that, his idea is not a very good one, unless your current protector isn't doing the job.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I would actually say that you should glue it back down in whatever way you decide and put a lizard skin over the whole thing. Keep it in original and keep the chainstay from getting beat up.
    Quote Originally Posted by jtmartino View Post
    The value of Homegrowns has crossed my mind. I certainly do not want that CS protector to fall off and be lost forever.
    Quote Originally Posted by zebrahum View Post
    Good idea!
    Reputation: Howley's Avatar
    Glue It!
    Contact cement - I'll use it to replace falling off ones or create one from old inner tube cut to shape and cleaned well with soap and water then rubbing alcohol. Paint both surfaces with thin layer of contact cement, let dry 5-10 min. sticks...like...glue!
    Attached Thumbnails Attached Thumbnails Reattaching my chainstay guard-hpim1687.jpg
  1. Chainstay guard on CC
    By huka in forum Surly
    Last Post: 07-11-2011, 08:52 PM
  2. I Want this Trek Chainstay Guard!
    By reactiontime89 in forum Trek
    Last Post: 02-22-2011, 07:47 PM
  3. Any need for chainstay guard on SS?
    By LukeTX04 in forum Singlespeed
    Last Post: 03-26-2009, 08:00 PM
  4. Chainstay Guard
    By kataclysm in forum Beginner's Corner
    Last Post: 08-20-2008, 07:18 AM
  5. 575 - chainstay guard?
    By KSC in forum Yeti
    Last Post: 09-09-2005, 02:08 AM
