Results 1 to 8 of 8
    May 2013
    Rear derailleur issue - need input
    Crashed on Tuesday, endo'd and the bike landed on the rear derailleur side. Chain came off the rear derailleur cogs, so I am guessing it's a bent hanger but looking for feedback.
    Now when it's in the front granny gear and the lowest rear cog (closest to the tire), when I try to shift back down, the rear derailleur won't move the chain until I put the front on the middle ring, essentially pulling the chain out or I pull just slightly with my hand when it's on my workstand and it pulls it off the cog, and then shifts no problem. So the issue only occurs when in the granny ring and the lowest gear.
    Thoughts??
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    try looking from behind the bike and see if the Der is bent ... or you might get more info here
    Drivetrain - shifters, derailleurs, cranks
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Thread already spun
    Reputation: Zowie's Avatar
    Aug 2013
    Were you in the lowest gear when you crashed? I used to have an older rear mech that was pretty screwed up around the second gear because I did something similar.
    May 2013
    Quote Originally Posted by Zowie View Post
    Nope. Was riding downhill so was in the middle front and somewhere in the middle in the back. I think the hanger was bent, tried straightening it out and it's a little better. Might just replace it.
    Quote Originally Posted by Stegerman View Post
    don't just replace it, you will be replacing all the time and at around 20bucks a piece, that would be crazy. Buy the tool for repairing derailluer hanger, and fix it, no big deal.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by 1362 View Post
    Even if you do replace it, you should still put a hanger tool on it to do the final adjustment. Just because the hanger is flat, doesn't mean it will be parallel to the wheel once it's bolted up.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by customfab View Post
    what he said...
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: jrastories's Avatar
    Check the hanger alignment and while you have the derailleur off pull the housing out of the stops on the frame to make sure all of the housing is in good condition not frayed or compressed. Put everything back togeather and re adjust the shifting.
    Rocky Element
    My Attempt at a Blog
  1. Rear derailleur shifting issue
    By 94hardtail in forum General Discussion
    Last Post: 08-02-2013, 07:29 PM
  2. Rear derailleur issue
    By dhelm72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-20-2012, 07:25 AM
  3. Rear derailleur Pulley issue
    By ColoSean in forum 29er Components
    Last Post: 10-02-2012, 11:01 AM
  4. Shimano XT rear derailleur issue
    By woohzle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-19-2011, 01:27 AM
  5. XX rear derailleur issue
    By discotu in forum SRAM
    Last Post: 02-17-2011, 04:56 AM
