Results 1 to 18 of 18
    dmo
    dmo is offline
    Reputation: dmo's Avatar
    Race face cranset not spinning smoothly
    Something is not right with the Race face crankset I'm trying to install. I had taken it off another bike and it had been working fine. I've also installed the RF BB and cinch crankset before with out problem but this time when I tighten everything down the crank arms don't spin freely. It's as if there is a ton of friction keeping them from rotating.
    I'm not sure what I did wrong. I greased the BB shell as well as the threads of the BB cups. Greased the spindle and inserted the non drive side crank arm into the BB. I placed the drive side crank arm into the splines and tightened the spindle bolt. Once doing that everything tightened up. I tried loosening the preload collar but that didn't help.
    I've done this before without problem but this time I'm missing something. Should I take everything apart and start over? What did I screw up?
    Sent from my SM-G955U using Tapatalk
    Aug 2015
    Dont think its suppose to spin freely with that preload. Mine spins about 1 revolution. It almost sounds like your BB bearings arent parallel to each other.
    Sent from my SM-G930V using Tapatalk
    dmo
    dmo is offline
    Mine don't spin at all
    I have to push the crank to get it to move
    Jun 2017
    My train of thought:
    -Are you 100% certain that the spindle length of the crankset is appropriate for the bottom bracket it's going into?
    -Are the bearings free to spin without the crankset installed?
    -Is the preload adjuster able to spin while the crankset is installed
    If the bearings are free to spin, then they're either getting pinched tight on the inner races (if spindle was too short, etc), or there's something that's pinching the outer race that shouldn't be. Anything that spins shouldn't touch the outer race or bottom bracket, so if there's anything that could be out of place and is squeezing both the inner and outer race, that would be an issue.
    dmo
    dmo is offline
    Quote Originally Posted by acedeuce802 View Post
    Thanks. That was helpful. I'll go over it again. I think maybe I have too many spacers
    Aug 2014
    Quote Originally Posted by dmo View Post
    I had this same issue once. Didn't realize the BB shell on the new bike was 73mm. The old one was 68mm. So i had to remove 2 of the BB spacers to on the new bike because the 73mm BB only uses one spacer where the 68 uses 3. this may be your issue.
    Niner Jet 9 Carbon
    Redline Conquest
    Breezer Thunder One
    Moto Boris
    GT Tequesta
    GT La Bomba
    Charge Grater
    Nashbar Carbon Road
    dmo
    dmo is offline
    Ya, I think that's my issue. Where does the spacer go for the 73mm BB?
    I'm #87!
    Reputation: Forster's Avatar
    Sep 2013
    Spacer placement is usually covered in instructions for a particular BB but my last build was a 68 that was cut a little smaller so I threw a 1.5mm spacer on the side the cranks were closest to the chainstays. Scientific? Nope, but it worked.
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
    Aug 2014
    Cinch crank, threaded bottom bracket. This should help out. http://www.raceface.com/media/B30067-B-Web.pdf
    Niner Jet 9 Carbon
    Redline Conquest
    Breezer Thunder One
    Moto Boris
    GT Tequesta
    GT La Bomba
    Charge Grater
    Nashbar Carbon Road
    Aug 2015
    I physically measured the distance between the crank arm and chainstay and try to get it the same.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by jacksonlui View Post
    Yes, they should spin perfectly fine with the preload properly adjusted. There should be no notable resistance. With the chain off, mine will easily spin more than a dozen revolutions if not more.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Aug 2015
    The dust seals usually provide some resistance. Ive never been able to spin my crank and have it spin a dozen revolutions.
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    Iím sure the answer is obvious, but itís a brand new bb right? Instructions for spacers are usually included.
    I know what it's like to be dead. "To Die & Live In LA."
    Magically Delicious
    Are you removing the chain (just taking it off of the chain ring)? That's really the only way to check the freedom and smoothness of the crank assembly. You should be getting way more than just one revolution of the crank.
    Yes, the dust seals will provide some resistance. I use a light grease light like Slick Honey on these to minimize friction and still provide and adequate dust/water barrier.
    dmo
    dmo is offline
    ...its wasn't a brand new bb. I didn't realize it was going from 68 to 73mm shell and had to many spacers. I installed the correct spacers and everything worked great.
    I figured it was something dumb
    Magically Delicious
    Just as a note regarding BB friction...this is going to have multiple variables that could factor into the coefficient of friction.
    Primarily, the grease used and how much of it. I prefer to use a light bearing grease like Buzzy's Slick Honey because of its viscosity. I'm sure if you are using a thicker, marine type grease, you are going to experience much more rotational friction.
    I'm using a Wheels Manufacturing Threaded BB.
    Aug 2015
    Thx for the input. Now i need to look at my own BB. I use an angular contact external threaded BB from enduroforkseals. My preloader is backed all the way out but its smooth and i can get 1-2 revs without the chain. I might need to add 1-2mm spacer and fine tune with the preload. Not really sure if it'll make much of a difference in saving power fighting that resistance but now its gonna be on my mind. You need to push against the angular contact bearings with the preload a little as i was told.
    Magically Delicious
    Here's my cranks...14 revolutions?
  1. Fixed & flat & now not shifting smoothly?
    By rickcin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2014, 06:16 PM
  2. What makes your shop time go smoothly?
    By sasquatch rides a SS in forum Tooltime
    Last Post: 05-15-2013, 01:07 PM
  3. Trouble with gears not shifting smoothly...Need help?
    By das028 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-10-2012, 04:45 PM
  4. Nexus 3 hub not spinning smoothly?
    By jsilva in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-25-2011, 07:17 AM
Members who have read this thread: 7
