Results 1 to 3 of 3
    Dec 2013
    Probably a simple answer, Nukeproof rear hub, so...
    I have noticed a bit of play in my nukeproof generator rear hub which I have had for about 6 months (rim moves about 5mm). I had a look at it just now and one of the axle ends (drive side) has a stripped thread. See top right picture on step 2:
    [How To] Nukeproof generator rear hub maintenance and bearing replacement by carloscorreia - Pinkbike
    Would this be enough to give the wheel play? Even with the QR tightened really tight?
    If so, new drive side axle end... if not.... bearings?..... already?.....
    Reputation: bvibert's Avatar
    Mar 2006
    When you say stripped thread, do you mean one thread is stripped, or they all are? Can you tighten the end cap at all?
    I don't know anything about those hubs, but if you can't tighten the end cap at all I'd think it could cause play, no matter how tight you make the QR.
    From the pictures it doesn't look like the end caps are threaded. First thing I'd check is make sure the quick release is holding the axle in place. These new style quick releases don't work very well.
    Put a drop of oil on the QR handle where it moves against the cam. Do the QR up very tight and see if that solves the problem.
    First thing I do with a new set of wheels is replace the rear quick release with a Shimano closed cam style.
    I've recently found that I need to replace front QR as well. Chased a similar problem with my Sun Ringle front, took the caps off and played around, finally found it was the QR.
  1. upgrade help..simple answer i promise...
    By h2bmess in forum Shimano
    Last Post: 04-30-2014, 04:43 PM
  2. Replies: 5
    Last Post: 02-08-2014, 07:49 AM
  3. simple forks for simple-minded riders
    By mack_turtle in forum Shocks and Suspension
    Last Post: 09-09-2013, 02:14 PM
  4. NEED A QUICK ANSWER, Seat Post Slot- Front or Rear?
    By Cracked Headtube in forum Fat bikes
    Last Post: 03-10-2012, 12:56 AM
  5. looking for deal on answer pro taper and answer dh one stem
    By david8613 in forum Where are the Best Deals?
    Last Post: 06-11-2011, 11:25 AM
