Results 1 to 29 of 29
    Presta air chuck
    Need a presta chuck for a standard air compressor hose fitting. Not finding one, thoughts?
    presta cycle, evt, park tool, air bob. make one
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    ya, I took a tire inflator..
    Sears.com
    took unscrewed the hose and got one of these....
    Amazon.com: Avenir Universal Head Bicycle Replacement Floor Pump Hose: Sports & Outdoors
    triggered and has a gauge...
    I actually took off the end and put a regular 1/4 inch air line quick release in line so I can just snap a Presta or Shredder head on ... but it's kinda clunky.. works great for inflating tubeless thou!!
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    I used that head but with the Harborfrieght inflator. That head will do both shraeder or presta at the same time so good to go with car tires too. Most prefer the pistol grip trigger
    Oct 2007
    Quote Originally Posted by Ratt View Post
    Yay, tried the harbor freight and a prestaflator which is the same as the pistol grip. The harbor freight one just broke in no time and the pistol I broke the gauge like 3 times ... the slide gauge is much more rugged for the garage!
    Mine is 4yrs old and doing ok but ya the dial face on the inside is bent with no visible damage to the outside. Could have been a roommate, they can be dorks sometimes.
    Don't need a $150.00 inflator, just the chuck. Does not look like the presta cycle is a standard hose size.
    Oct 2007
    Quote Originally Posted by leeboh View Post
    look on AMAZON, do a google search.. there are tons of diff heads... Topeak, Black Burn Adesso, all sorts...
    example...
    Amazon.com: bicycle pump head
    Dec 2010
    Are you just looking for a plain ol' silca chuck?
    I have a silca head, does not thread into the blower handle. Maybe yall not getting my drift. Standard garage shop air compressor hose have a quick release fitting. Snaps in and out. Every car shop has a fitting that fills up schrader valves. I need a quick connect with a presta valve end. Clearer?
    Dec 2010
    Presta inflators don't work like schrader inflators.. You need more than just the chuck to fill tubes. With a presta inflator you need some sort of trigger to regulate airflow...if you just put a presta chuck in the end of an air hose air will rush out constantly without control.
    Oct 2007
    ya,.. you're gunna have to build it... ...
    you can get a head, thread it onto a air line quick release and off ya go..
    you WILL want a trigger of some sort sa a bike tire won't handle the high pressure of air from a compressor without some control.. you'll blow it up. a regular air blower will work OK but having a gauge is a big help.
    Reputation: hankscorpio's Avatar
    Jun 2012
    Can you just use a presta to shrader adapter to use an air compressor?
    Dec 2010
    Quote Originally Posted by hankscorpio View Post
    Yep. And they usually don't cost much more than $1.
    Jun 2012
    so why go through this whole mess of finding a presta chuck?
    Oct 2007
    yup. but sometimes they are a pain depending on the stem manufacturer.. I've had a few that I just can't get the presto valve to sit right so the Shrader head would push down enough to get a good air flow. plus they are jus a pain.. unscrew the presto valve, screw on the adaptor, inflate, unscrew the adaptor, screw in the presto valve... loose the adaptor when it rolls under something in the garage,.. spend hours digging around for it..
    drive to the local shop get another...... LOLOLOL
    Dec 2010
    Maybe OP wants a presta chuck...
    Jun 2012
    Fair enough
    OK, so need air type regulator, makes sense. Unless I just set the max air output on the compressor to X psi.
    I like turtles
    Reputation: TiGeo's Avatar
    Here is mine. Got a prestafaltor head and just added it to existing air tools I had. Works perfectly. I have no idea why I waited so long. For tubeless...there is no substitute for air volume/pressure!
    Attached Thumbnails Attached Thumbnails Presta air chuck-1525047_10151921089771723_1693683839_n.jpg
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Oct 2007
    Quote Originally Posted by TiGeo View Post
    ya, that's nice, I hated to old Prestaflator heads that didn't have the 90 degree bend, can't tell ya how many times I waste a knuckle on the spokes from that, that new one looks MUCH better!!
    I like turtles
    Me too...many dinged knuckles when I worked in the shop from our straight presta gun.
    Sent from my SCH-I545 using Tapatalk
    to get a silca head onto a blow gun or whatever you need to chop the barb off the end and tap it with a 1/8npt tap. this will let you thread in plumbing fittings and what not
    Jun 2012
    Dec 2010
    This tip works ok, but only with certain schrader chucks. Some different designs don't work well.
    I did all the home built presta chucks and ended up getting a good deal on the park one. It works great and also has the schrader so it works on cars, mowers and lots of other stuff. I wish I would not not have wasted all the money on the home built stuff now.
    Oct 2007
    Quote Originally Posted by dlennard View Post
    umm at well over 100 and a 1/4 bucks for that thing.. I can build like 5 more.. it is nice though!
    Quote Originally Posted by thomllama View Post
    The key word was "good deal". I ended up finding one for $80. It does work better than all the other stuff I made.
    So had a prestaflator chuck but the end of the blow gun was too large, home depot sells a kit that has a smaller blow gun+ threaded adapter to fit, win!
  1. presta valve chuck for air compressor
    By rmoore in forum 29er Components
    Last Post: 01-23-2015, 12:34 PM
  2. Cheap Presta Chuck that works great!
    By cman8 in forum Tooltime
    Last Post: 07-23-2013, 03:17 PM
  3. Chuck CR-FS
    By rosbif in forum General Discussion
    Last Post: 04-21-2012, 08:07 PM
  4. Brain Cramp - Presta Chuck
    By RSWMTB in forum Tooltime
    Last Post: 08-26-2011, 07:35 PM
  5. Chuck
    By Andy aka Rut in forum California - Norcal
    Last Post: 06-18-2011, 07:00 AM
Members who have read this thread: 12
