    Oct 2010
    Piston on calliper stuck and won't retract
    I've searched in these forums and can't find the answer I need. I've been reading ppl saying do not press lever without the wheels on. Well what happens if you do?
    I left my bike on the work stand after refilling/bleeding my brakes and after coming back to it, my house mate was messing about and started squeezing the lever without the pads or wheel in. Now I've got a piston that will not retract. I've tried with force, unscrewing bleed screw on lever and the thing will not retract.
    Any help?
    beater
    Reputation: evasive's Avatar
    Feb 2005
    You'll have to press it in. Park makes a tool specifically for that (of course). I use a metal tire lever. Use something wide enough to distribute the force so you don't mark up the piston. If it doesn't want to go, try lubricating the edges of the piston with a cotton swab dipped in brake fluid. Make sure that you're not pressing it in at and angle and binding it.
    Oct 2010
    Quote Originally Posted by evasive View Post
    Mate! So simple! All good now. I was using a flat head and was on an angle but then did as you said and used the round side of a wrench and "presto!" It popped in and oil went shooting out the lever.
    Cheers bud
    beater
    Feb 2005
  1. REALLY stuck caliper piston - Elixer CR
    By Oh My Sack! in forum Brake Time
    Last Post: 08-27-2013, 12:40 PM
  2. Stuck Piston - Formula RX
    By divernick in forum Brake Time
    Last Post: 10-20-2012, 02:35 PM
  3. Stuck piston on Magura sl
    By patrickd72 in forum Brake Time
    Last Post: 08-15-2012, 12:52 PM
  4. Hayes Stroker Ryde piston won't retract
    By rider70 in forum Brake Time
    Last Post: 06-23-2011, 05:30 PM
  5. Stuck Piston
    By Rinaldo Moon in forum Brake Time
    Last Post: 06-20-2011, 08:20 PM
