Results 1 to 3 of 3
    Mar 2014
    NEWbie Front Derailleur Issues: HELP
    So I'm trying to adjust a front derailleur. I've watched some youtube videos and understand that there are some screws to do like a micro adjustment on it and I've tried it, but it's not working.
    Whats happening is, when I shift up to the high sprocket it wants to push the chain past that sprocket. When I adjust those little screws slightly it to where it fits on the big sprocket, it then wants to push the chain off of the bottom sprocket when I shift down or it will completely skips the middle sprocket.
    Any suggestions would help.
    Thanks for your time.
    Re: NEWbie Front Derailleur Issues: HELP
    Read this. It sounds like you are fighting improper limit setup as well as improper cable tension.
    Mar 2014
    Quote Originally Posted by wschruba View Post
    WOW, that is exactly what I needed. I'm going to go try these instructions and see if it resolves my problem. I wish I knew this was out there already. Thanks for pointing me in the right direction.
  1. RIP9 alloy - front derailleur issues?
    By Jisch in forum Niner Bikes
    Last Post: 08-08-2013, 02:31 PM
  2. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  3. Tracer VP / X9 Front Derailleur / Issues
    By xnofriendsx in forum Intense
    Last Post: 09-12-2011, 11:09 PM
  4. Newbie with some front derailleur ?'s
    By rlouder in forum Beginner's Corner
    Last Post: 06-08-2011, 04:59 PM
  5. Fantom 29PRO SL Front Derailleur Issues
    By flagrider3 in forum Motobecane
    Last Post: 04-06-2011, 01:04 PM
