    Reputation: AndesJack's Avatar
    New Stem Loose Fork
    Replaced the stem on my bike with a shorter one and after all the bolts were tightened felt that the fork was loose. Noted a small gap of perhaps 1.5 - 2.5mm between the top cap and the spacer/shim used up top. Followed the normal assembly procedure I always follow: Center Stem, tighten top-cap screw, tighten side bolts to torque and done.
    Any advice will be greatly apprecaited.
    When in doubt, Accelerate!
    Need a thicker spacer under the stem. The top cap is hitting the fork before the preload is correct.
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: New Stem Loose Fork
    Yep, sounds like your new stem has a shorter stack height. You need to add a spacer either under or on top of the stem.
    Sent from my DROID RAZR using Tapatalk 4
    Many thanks. Problem solved!
  1. loose headset/fork play
    By kwest10 in forum Shocks and Suspension
    Last Post: 01-29-2013, 05:54 PM
  2. Loose Uppers on Brand New 66 Fork?
    By colburnracing in forum Downhill - Freeride
    Last Post: 11-27-2012, 06:16 PM
  3. '12 Marlin Front fork at the frame is loose
    By budjev in forum 29er Bikes
    Last Post: 03-30-2012, 10:42 AM
  4. Loose fork/star nut??
    By Houndog45 in forum Singlespeed
    Last Post: 01-13-2012, 10:52 PM
  5. 2010 giant trance x 4 fork loose
    By drivengsxr1000 in forum Giant
    Last Post: 09-17-2011, 08:16 PM
