Results 1 to 7 of 7
    New bike can't find creak/click
    2014 niner rip9 xt build
    It's a clicking noise under strong pedal force.
    It occurs in or out of saddle.
    I don't think it's the crown I did the wheel between legs and torque the bars test.
    Things I have tried:
    Greased axles
    Greased/tightened pedals
    Greased tightened chain ring bolts.
    Snugged pivot bolts
    Still on list to do:
    Could it be a spoke?
    Bottom bracket? (Mine is the xt threaded type)
    Any other ideas?
    Reputation: squareback's Avatar
    Re: New bike can't find creak/click
    If you have Shimano pedals, try borrowing another pair of pedals. I have had pedals that can't be quieted, so regreasing them was a false elimination.
    sent remotely
    Cassette lock right might not be tight enought or QR not super tight. Seen that before. Also had chains that would click. Try another set of wheels to. Then you know if it's wheel related.
    Can you say Full XO #22.68 salsa moto rapido
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Earbuds with music. Every bike I've owned has clicks and creaks. Some culprits have been the fork crown to stanchions interface, seat post in the seat tube, headset, pedals, worn bb. Unless something is keeping the bike from being rideable or is a safety issue, I ignore it.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    I swapped pedals and that wasn't it. I'll grease/snug the bb tomorrow and snug up the cassette. If that doesn't work I know music will! Thanks for the tips.
    Quote Originally Posted by bluewave View Post
    Check your cassette. I had a similar issue and chased it down to my cassette needing to be re-torqued. It wasn't "Loose," but needed to be snugged up.
    Plays with tools
    Reputation: customfab's Avatar
    I've seen more BB's creak because they're too tight than too loose. Best of luck, it can be frustrating to track these things down.
  1. A Fox CSU that DOESN'T click/pop/creak?
    By Pau11y in forum Shocks and Suspension
    Last Post: 07-02-2013, 11:25 AM
  2. Bike creak
    By cornice6 in forum Tooltime
    Last Post: 03-19-2013, 07:44 AM
  3. Bottom Bracket click click click click
    By Loll in forum California - Norcal
    Last Post: 07-06-2012, 07:56 PM
  4. Crest rim could save your bike "click on photo"
    By flyag1 in forum 29er Components
    Last Post: 02-02-2012, 03:49 PM
  5. i-drive creak creak creak
    By slo65 in forum GT
    Last Post: 04-18-2011, 07:54 AM
