Results 1 to 6 of 6
    May 2013
    Need new derailleur - long cage or mid cage?
    Just want to check which cage length derailleur I need for my Trance X0 2012. The old (now broken) one only has the model RD-M780 marked on it. Its an XT Shadow 10 speed derailleur for a 11-36T casette and 26x38 front chainring. It's just the stock Trance arrangement. I don't know why they cant just mark this sort of stuff on it or have a different model number
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    first you're in the wrong section.. go over to drive train...
    and, there is a sticky post there that show you how to figure it out.. pretty simple math
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Nov 2007
    you need a long cage with the 36T. A mid cage would only get you up to a 30T. I have a mid XTR on my Cross bike with a 30T. I think if I remember when borrowing a wheel the 32 was getting too close to the jockey wheels even with the B screw turned in all the way
    Dec 2012
    Hi bro, you definately need the long cage derailleur , i ride 2012 trance x1 which uses the same rear derailleur as xo.
    MTB B'dos
    Reputation: LyNx's Avatar
    Really, that's your honest opinion and you're sticking to it? A mid cage RD will work just fine with even up to a 36t cog, the problem lies in it taking up enough of the chain slack in bad gear combos since there's such a big jump in the front rings, but in no way, shape or form will you have trouble with keeping the upper pulley off the cassette cogs He is right that a long cage would work better if you insist on using all gear combinations, if you however don't do that a mid cage could work just fine.
    Quote Originally Posted by oberwil View Post
    If you are just trying to determine the cage you have now - my SLX long cage is 100mm between the jockey wheel bolts and my medium cage is 80mm.
    If you are trying to determine what you need - you need to take up 37 teeth of chain. Shimano medium derailleurs are only rated for 35 teeth. On a hard tail I'd go with the medium anyways but since you have a FS, I'd say the long cage would be safer - the suspension movement may require additional chain take up capacity.
  1. When to use a Long Cage vs Short Cage Derailleur?
    By Trentkc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-17-2017, 02:00 PM
  2. When to use a Long Cage vs Short Cage Derailleur?
    Last Post: 01-04-2016, 02:03 PM
  3. Shimano Exage Long Cage vs. Acera Long Cage
    By jeffj in forum Vintage, Retro, Classic
    Last Post: 11-12-2013, 05:53 AM
  4. Need Help-Can I use X9 Long Cage Pulley/Spring Assembly for XO Rear Derailleur Cage?
    By red bank rider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2013, 09:58 AM
  5. Replies: 3
    Last Post: 02-20-2012, 07:42 PM
