Results 1 to 3 of 3
    Reputation: tapcon's Avatar
    May 2013
    Need Help With BB Adapters
    I have a 2011 Trek EX7. I want to change to a 2x10 configuration with a Shimano XT setup. I currently have a SRAM S1000 crankset. As you can see from the pics below, it is a PF design.
    I know I have to get an adapter, but I'm confused as to which one. Can someone please point me to the right direction. These are the two which I am considering:
    Wheels Mfg PF30 Adapter For Shimano With PF30 Bottom Bracket - Competitive Cyclist
    Wheels Mfg PF30 Adapter For Shimano - Competitive Cyclist
    Whether you're peddling or twisting the wrist...you're still riding on two wheels...and that's good enough for me
    Looks like the only difference is one of your links includes a new bottom bracket. The other is just the adapters, you would use your present BB.
    You sure it's PF30 and not BB30? Hard to tell from the pictures.
    Bottom Bracket Standards - a guide to BB30, PF30, and Outboard Bearing compatibility
  1. Are all IS adapters the same?
    By f3rg in forum Brake Time
    Last Post: 03-03-2013, 03:35 PM
  2. BB30 Adapters
    By riding29 in forum Niner Bikes
    Last Post: 07-01-2012, 02:22 PM
  3. 20mm Adapters
    By SoCalNomadRider in forum Canfield
    Last Post: 02-06-2012, 03:19 PM
  4. MS to Marwi adapters
    By El34 in forum Lights DIY - Do It Yourself
    Last Post: 01-02-2012, 02:53 PM
  5. Which brake adapters for EG
    By meSSican in forum Titus
    Last Post: 11-25-2011, 12:29 PM
