    Reputation: brankulo's Avatar
    Aug 2005
    my diy wheel truing stand
    since i am going to build my first set of wheels i decided to make myself a wheel stand. very simple design and cheap. cost less than $5 for some bolts, nuts and washers i didnt have in my garage.
    Uploaded with ImageShack.us
    Great job, but how are you going to repeat the position of the wheel as you take it out and put it in over and over during the process? I guess in reality it really doesnt matter, but Im thinking those bolts that go through where the skewer goes are not going to offer enough rigidity?? Youd probably be better off with an actual skewer through there, or a single bolt. I may be wrong, but other than that, good work!
    Aug 2005
    the idea is to push two triangular parts together against locknuts, so i can reposition it the same way as there is snug fit. no need for skewer as wheel is supported on threaded axle. tried it with my current wheels, works well.
    Reputation: Shalom's Avatar
    Nov 2008
    Great idea. Simple and looks to be functional.
    Good luck with your first wheel build.
  1. Park Tool Wheel Truing Stand TS-2.2
    By Alex Berger in forum Tooltime
    Last Post: 07-28-2010, 10:40 AM
  2. Wheel truing with a trainer as a stand
    By naiku in forum Wheels and Tires
    Last Post: 03-26-2010, 08:43 PM
  3. wheel truing stand recommendations
    By frorider in forum 29er Bikes
    Last Post: 05-08-2008, 12:25 AM
  4. good wheel truing stand
    By bandit350 in forum Wheels and Tires
    Last Post: 04-16-2006, 07:51 AM
  5. Need a low budget wheel truing stand?
    By Mike T. in forum Wheels and Tires
    Last Post: 04-09-2006, 07:34 AM
