Results 1 to 15 of 15
    Reputation: Hoban's Avatar
    Oct 2012
    My DIY wheel building/truing stand
    I really want the Park pro truing stand but am not excited about spending $250 on it. Maybe the next set of wheels.
    So I had some scrap steel and after looking at Roger Musson's steel wheel jig I decided to whip one up. Took me 2-3 hours today, but I think it came out nice. Just screwed 1/2 wood shelving for the bottom to save some weight. I may but out some 11 ga and weld it up but this will work for now.
    I used 3/8 all thread and 5/16 rod for the T handle. I used 3/8 coupling nuts for the t-handle mounts and the jig adapter to hold the hub. I drilled it out a touch to fit perfectly over the front hub nipple. It isn't large enough to slip completely over the 9mm threaded rear hub nipple, but it's easy enough to pick a couple more and drill them to fit.
    I made it wide enough to fit up to a 142 axle, but will have to use smaller coupling nuts. Just need to paint!
    turtles make me hot
    Reputation: NYrr496's Avatar
    Cool. How do you make the wheel straight?
    I like turtles
    Oct 2012
    I'm going to make a moveable gauge that does both lateral and radial trueness. It'll lock down with a wing nut to the wood platform.
    turtles make me hot
    Nice.
    I like turtles
    Reputation: bvibert's Avatar
    Mar 2006
    Nice work!
    Nice.
    here's mine:
    Thread here:
    My custom pro truing stand
    Oct 2012
    Evrac, I like yours. I was initially going to grind the tips of bolts/all thread into points but I wanted it to be more precise. Although I'm a SURGEON with a grinder. I also couldn't find pivot bolt with swivel tips on them anywhere. What did you use for your locating bolts?
    I made up a quick gauge. I just flip it around to do the radial. Not elegant, but I haven't built a set of wheels from scratch so I'm sure it will evolve.
    Plays with tools
    Reputation: customfab's Avatar
    That'll do. I would be tempted to use some light gauge steel in place of the melamine so you could mount a magnetic base for a dial indicator on it. It's over kill for building wheels but they are flexible and precise.
    Oct 2012
    Good idea, I may do the base with steel later. I did the shelving to get a white background.
    However, I could also mount my dial indicator magneted to an upright if I were to try use one.
    Oct 2012
    Got my 15mm adapters from mtbiker4like on Ebay. Inexpensive, and very fast shipping. Excellent product.
    Plays with tools
    I've got a set of those I would have given you. I didn't care for them so I made a couple hundred of my own.
    was trying to see if can i get this TRUING STAND going and looks like it will. Just waiting for CUSTOMFAB's adapters (if i can figure out how to get them) for use with 12/15mm thru axles..
    would you believe this design is being sold for close to $100 shipped? not including the DIAL INDICATORS, this design will be under $50 cheaper if you have left over materials.
    got the design from Google Image Result for http://tuckamoredew.files.wordpress.com/2011/08/imgp4113.jpg and modified it by trying to see if can use DIAL INDICATORS instead.
    Attached Thumbnails Attached Thumbnails My DIY wheel building/truing stand-img_5170.jpg
    My DIY wheel building/truing stand-img_5172.jpg
    My DIY wheel building/truing stand-img_5173.jpg
    My DIY wheel building/truing stand-img_5174.jpg
    2014 TREK FARLEY
    2013 TREK RUMBLEFISH PRO
    2012 TREK SUPERFLY AL ELITE
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Quote Originally Posted by customfab View Post
    If you're not happy with your purchase please send them back and I will refund your money. I realize my designs may not please everyone because we all have a different way of looking at the problem/solution. Thanks
    Plays with tools
    Quote Originally Posted by mtnbiker4life View Post
    If you're not happy with your purchase please send them back and I will refund your money. I would appreciate it if you would not slagg my tools. I realize my designs may not please everyone because we all have a different way of looking at the problem/solution. Thanks
    Saying I didn't care for them is different from slagging them off. At least in my eyes. Your adapters are perfectly functional and get the job done. But I saw room for improvement, so I improved.
    Wow, nice. Where'd you get those dial indicators? That would make any stand even more precise. Again, super nice!!!!
    We Ride In God's Country!
  1. Repair Stand Mounted Wheel Truing Stand?
    By homey in forum Tooltime
    Last Post: 10-08-2016, 11:25 PM
  2. Wheel truing stand-DIY
    By Mr.Magura in forum Tooltime
    Last Post: 08-05-2012, 04:54 AM
  3. What wheel truing stand?
    By aBicycle in forum Tooltime
    Last Post: 07-24-2012, 04:35 PM
  4. Replies: 9
    Last Post: 05-28-2012, 05:10 AM
  5. my diy wheel truing stand
    By brankulo in forum Tooltime
    Last Post: 08-21-2011, 06:26 PM
Members who have read this thread: 14
