Results 1 to 16 of 16
    Dec 2010
    My DIY Derailleur Hanger Alignment Gauge (that also cost nothing)
    Many have said a derailleur hanger alignment guide could not be made from scratch, I beg to differ I had a steel tube in the garage that was flat on the end with a hole in it (just happened to be the perfect diameter). I also had a derailleur bolt (with C clip) from an old Shimano derailleur that was about an inch long. I simply gathered the other parts I needed (axle spacer and axle washer) and put it together. The 5mm derailleur bolt spins freely so you can use a hex wrech to thread it in the hanger and the pipe was a perfect length (to just meet the top of a 29" rim with the tool threaded into a hanger). While it doesn't actually have a nice feeler gauge to meet the rim, I figure I can just use a ruler. I can easily check the distance from the rim to handle of tool by just holding the ruler on the handle and extending it to the rim surface. Not bad for 5 minutes and some scrap steel
    Final tool
    Top view
    Bottom view of washer, spacer and C clip
    Reputation: gmats's Avatar
    Apr 2005
    Aloha, nice, great job.
    Reputation: bvibert's Avatar
    Mar 2006
    Looks good!
    Dec 2010
    Future idea for this tool is a Plasti-dipped handle. I think that will finish it off nicely.
    Plays with tools
    Reputation: customfab's Avatar
    Is the flat section rigid enough to allow you to adjust the hanger?
    All in all not bad for a home version. It doesn't look quite solid enough for some of the 11spd drive trains that need that last bit of precision though.
    Dec 2010
    Definitely strong enough for 99% of hangers out there. I could see it struggling on thicker, steel hangers like on Surly frames, but it could do anything else with ease. I don't plan on ever bending the derailleur hanger on my Surly, but if I do I'm definitely going to post up results here of how the tool performs.
    Reputation: IRONMAN1518's Avatar
    Very nice, and .....simple, great!! Hope you publish more ideas.
    Training on Hills Builds Character, That's How I Got To Be One!
    Dec 2010
    I got some time (and warm enough weather) to Plasti-dip the handle. I've never used Plasti-dip before, but it's really cool. It did a great job and seems pretty strong. I scuffed up the area that I coated so I shouldn't have any issues with it peeling back at all. I've been able to use the tool a few time since I made it and it's really working awesome. I ended up switching the hardware around on the end and putting the washer on the outside for a little more stability. All-in-all a very useful tool.
    Dec 2010
    Just thought I'd give an update. This thing has been holding up great! No issues so far and I ended up getting the spare parts to make a second
    Plays with tools
    My DIY Derailleur Hanger Alignment Gauge (that also cost nothing)-hag-full.jpg
    I went the complete opposite route when I made a hanger tool. Went for that last bit of precision that you can't get with other tools on the market. It was a bit of a process but the end result is pretty spot on.
    Dec 2010
    Quote Originally Posted by customfab View Post
    Doesn't really fit in with the whole "DIY" theme of this thread, but nice job
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by sasquatch rides a SS View Post
    Except he did do it all himself.
    mtbtires.com
    Dec 2010
    Quote Originally Posted by shiggy View Post
    Not exactly something the average Joe can do himself, though. In the big picture, it doesn't quite fit the DIY theme.
    Reputation: arphaxhad's Avatar
    It also doesn't fit the "that also cost nothing" theme of the thread. As a professional machinist (i am only going by his website) I'm certain that the mockup and fabrication of the tool took at least several hours. At his hourly shop rate, + materials, I'm sure that the initial process cost at least the $170 he sells them for.
    Love the ingenuity Sasquatch! Frankly that type of solution is more impressive to many than CustomFab's obvious fabrication chops.
    Reputation: emeterio's Avatar
    may you upload again pics, they appear to be broken links
    No dudes, no temas, no te arrepientas.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Do
    It
    Yourself.
    Yes both of the above are D.I.Y..
    Good job to both of you guys.
    Myself it was worth the $60 to just buy the Park DAG-2 but I agree D.I.Y. Projects are fun.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
Members who have read this thread: 9
