• 02-26-2013
    sasquatch rides a SS
    My DIY Derailleur Hanger Alignment Gauge (that also cost nothing)
    Many have said a derailleur hanger alignment guide could not be made from scratch, I beg to differ ;) I had a steel tube in the garage that was flat on the end with a hole in it (just happened to be the perfect diameter). I also had a derailleur bolt (with C clip) from an old Shimano derailleur that was about an inch long. I simply gathered the other parts I needed (axle spacer and axle washer) and put it together. The 5mm derailleur bolt spins freely so you can use a hex wrech to thread it in the hanger and the pipe was a perfect length (to just meet the top of a 29" rim with the tool threaded into a hanger). While it doesn't actually have a nice feeler gauge to meet the rim, I figure I can just use a ruler. I can easily check the distance from the rim to handle of tool by just holding the ruler on the handle and extending it to the rim surface. Not bad for 5 minutes and some scrap steel :D
    Final tool
    Top view
    Bottom view of washer, spacer and C clip
  • 02-26-2013
    gmats
    Aloha, nice, great job.
  • 02-27-2013
    bvibert
    Looks good!
  • 02-27-2013
    Future idea for this tool is a Plasti-dipped handle. I think that will finish it off nicely.
  • 02-27-2013
    customfab
    Is the flat section rigid enough to allow you to adjust the hanger?
    All in all not bad for a home version. It doesn't look quite solid enough for some of the 11spd drive trains that need that last bit of precision though.
  • 02-27-2013
    Definitely strong enough for 99% of hangers out there. I could see it struggling on thicker, steel hangers like on Surly frames, but it could do anything else with ease. I don't plan on ever bending the derailleur hanger on my Surly, but if I do I'm definitely going to post up results here of how the tool performs.
  • 02-27-2013
    IRONMAN1518
    Very nice, and .....simple, great!! Hope you publish more ideas.
  • 04-01-2013
    I got some time (and warm enough weather) to Plasti-dip the handle. I've never used Plasti-dip before, but it's really cool. It did a great job and seems pretty strong. I scuffed up the area that I coated so I shouldn't have any issues with it peeling back at all. I've been able to use the tool a few time since I made it and it's really working awesome. I ended up switching the hardware around on the end and putting the washer on the outside for a little more stability. All-in-all a very useful tool.
  • 01-25-2014
    Just thought I'd give an update. This thing has been holding up great! No issues so far and I ended up getting the spare parts to make a second :thumbsup:
  • 01-28-2014
    customfab
    Attachment 865781
    I went the complete opposite route when I made a hanger tool. Went for that last bit of precision that you can't get with other tools on the market. It was a bit of a process but the end result is pretty spot on.
  • 01-28-2014
    Originally Posted by customfab View Post
    Attachment 865781
    Doesn't really fit in with the whole "DIY" theme of this thread, but nice job :thumbsup:
  • 01-28-2014
    shiggy
    Except he did do it all himself.
  • 01-28-2014
    Not exactly something the average Joe can do himself, though. In the big picture, it doesn't quite fit the DIY theme.
  • 01-29-2014
    arphaxhad
    It also doesn't fit the "that also cost nothing" theme of the thread. As a professional machinist (i am only going by his website) I'm certain that the mockup and fabrication of the tool took at least several hours. At his hourly shop rate, + materials, I'm sure that the initial process cost at least the $170 he sells them for.
    Love the ingenuity Sasquatch! Frankly that type of solution is more impressive to many than CustomFab's obvious fabrication chops.
  • 07-10-2015
    emeterio
    may you upload again pics, they appear to be broken links
  • 07-12-2015
    PauLCa916
    Do
    It
    Yourself.
    Yes both of the above are D.I.Y..
    Good job to both of you guys.
    Myself it was worth the $60 to just buy the Park DAG-2 but I agree D.I.Y. Projects are fun.
