Results 1 to 8 of 8
    Multi tool with T15 torx
    Is there a multi tool with Torx T15 & T25?
    Reputation: Nubster's Avatar
    This is what I came up with, not much help....sorry
    Crank Brothers Pixl Premium has T10 and T25
    Soma Woodie 20 has T10 and T20
    Lezyne RAP 20 has T25 and T30
    SKS Toolbox Travel 18 has T20 and T25
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Reputation: purdyboy's Avatar
    It appears you can buy the Lezyne torx separately and then swap out other sizes on any Lezyne 'SV-10' type multi-tool with the forged/machined bits.
    Well at least I think this is possible as it is what I just ordered last night...
    Here's the type of tool ordered:
    Lezyne V10 Multi Tool | Buy Online | ChainReactionCycles.com
    Here are the bits offered separately:
    Lezyne Torx Multi Tool | Buy Online | ChainReactionCycles.com
    (sizes T6, T7, T9, T10,T15, T20, T25, T27, and T30).
    Internet searches indicate that the higher end SV-10 etc range of multi-tools can be dismantled and built it up with just the tools to suit your bike / ride type etc.
    Good luck.
    Ride Safe.
    www.lighttouchchiropractic.com.au Manly Sydney
    Quote Originally Posted by purdyboy View Post
    Good luck.
    I didn't notice that when I was looking around. That's pretty cool that you can do that. Thanks for the info.
    Kona Big Unit SS
    Jun 2012
    The park MTB-3 may have one.
    Plays with tools
    Reputation: customfab's Avatar
    What on your bike takes a T15?
    Thanks purdyboy...dang I ordered from CRC last week already too!
    @customfab - Formula R1 brake clamp screws
    Follow up...
    Yep the separate torx tool came and it will fit the Lezyne SV10.
    You can dismantle the tool and either change-out the new torx bit for an existing tool bit that you won't use or grind down one of the spacer washers and fit the extra tool. Remember to put locktite on the bolts holding the whole tool together.
    Happy with the tool - I got the vanadium one, not the stainless. Still feels like quality.
    Suits my 'weight weenie-ness' as it halved the weight of the tool I carry whilst giving me the torx bits that I may need on the trail.
    Will play around with spacers and minimising to only carry the bits actually needed on the trail, should further reduce weight/size.
    Ride Safe.
