Results 1 to 7 of 7
    Jun 2013
    Mountain bike cable problems
    I crashed by sliding out around a corner and ended up with some road rash.
    My rear derailleur wasn't shifting as far out as possible. I tracked the problem down and noticed that the cable was cracked were it entered the SLX Shifter.
    I'm wondering what pieces need to be replaced and the cheapest way possible? It appears the fibers of the cable are sticking out where it enters the housing.
    To replace this do I cut the line, get a new cable, feed it in, and use the same funnel piece. The funnel piece appears to be a screw knob.
    Bike: 2010ish GT Zaskar SLX parts
    Reputation: bvibert's Avatar
    Mar 2006
    I'm guessing the 'funnel piece' is the cable tension adjuster? That typically isn't replaced when replacing cables, if it's damaged and doesn't turn then you'll probably want to get a new one (if they're available).
    The procedure to replace the cables will be slightly different than shown in the video above, since you have Shimano shifters. In particular you typically don't need to remove Shimano shifters from the bike, and you won't need to remove the bottom cover.
    https://www.youtube.com/watch?v=veTpataOTeY
    Replace the cable and housing together, it's not worth saving a few bucks by trying to reuse the housing by shortening it. You may run into problems with the housing being to short if you do that.
    If you crashed hard enough to damage your shift cable I'd check over the rest of the bike to make sure nothing else is damaged. The rear derailleur and hanger would be of concern to me.
    Jun 2013
    it appears that the housing is damage which is stretching the cable to much to get in the highest gear.
    How important is it to get expensive cables? I figured a few bucks at the local co-op or a cable kite for $40? Jagwire Mountain Pro Shift Cable Kit > Components > Cables and Housing > Shifter Cable and Housing | Jenson USA
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    yes, easy to do...
    remove cable
    remove housing pieces
    bring to local bike shop
    ask them to cut you new housing same size as old pieces
    ask for replacement cable
    or do the above yourself online and with a bike specific cable/housing cutter, or a parallel-action wire fence cutter with flat faces (flush cutter) not scissor-like cutters.
    Mar 2006
    I usually just buy some of whatever bulk housing my LBS has available.
    Jun 2013
    fixing it tonight, wish me luck. Hopefully, I won't need it
  1. Replies: 1
    Last Post: 04-02-2014, 10:57 AM
  2. Road Bike Mountain Derailleur Cable Routing Issue
    By arnobarno in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2012, 10:25 PM
  3. White Mountain: snow problems
    By M-80 Rider in forum California - Socal
    Last Post: 10-17-2011, 07:51 PM
  4. 2009 Sultan front derailleur cable hose rubbing problems
    By Midle Age Warrior in forum Turner
    Last Post: 07-13-2011, 09:06 AM
