Results 1 to 1 of 1
    Most accurate floor pump gauge
    Which floor pump has the most accurate gauge for both low MTB psi and high psi road pressure?
    I cant speak for other brands , but my Specialized sport pump was pretty much spot on, even when i took the greenway tires up to 65-70psi
    Sent from my DROID RAZR using Tapatalk 4 Beta
    Plays with tools
    Reputation: customfab's Avatar
    If you care that much you need to send your gauge off to have it calibrated. Might be able to replace it with a NIST certified gauge for less though.
    The important thing is consistency. Find a pressure you like with a given pump and it's repeatable, whatever the true pressure is is somewhat irrelevant. If you absolutely must know exactly how much pressure is in your tires you'll need more than an off the shelf pump.
  1. Replies: 3
    Last Post: 04-13-2013, 01:27 PM
  2. Lezyne floor drive pump pressure gauge info
    By DennisF in forum Tooltime
    Last Post: 02-25-2013, 01:49 PM
  3. Lezyne Micro Floor Drive ... with gauge?
    By rjx in forum Beginner's Corner
    Last Post: 10-03-2012, 01:39 PM
  4. Park PFP-4 floor pump stuck gauge
    By VTSession in forum Tooltime
    Last Post: 06-30-2012, 08:59 PM
  5. Digital Tire Gauge Accurate at Low PSI?
    By onepivot in forum Fat bikes
    Last Post: 05-13-2011, 01:42 PM
