Results 1 to 59 of 59
    On MTBR hiatus :(
    (MkIII) Homemade Headset Tools...
    <P><table border=1 bgcolor=DAFFC4 width=500><tr>
    <td align=left><font size=3 face=arial><center>This post is one in a series of twelve posts depcting the build of my Hollowpoint MkIII.
    <a href="http://forums.mtbr.com/showthread.php?t=130055"><b>Link to <font color="blue">MkIII / Speedhub bike build post.</b></font></a></center></td></tr>
    </table></P>
    <table width=500><tr><td align=left><font size=3>Oh goody, more homemade tool solutions.
    About four years ago, I put together a post titled "Thanks Gearjunky - 99&cent; headset cup remover". It was a length of PVC tubing sliced open at the ends to impersonate a headset cup remover. Only problem was that every few uses, the PVC would become chipped along the edges and eventually shatter. Someone much smarter than I ran with Gearjunky's idea, but made their tool out of copper pipe. Not too long ago, I copied, and have been using this for maybe a year already. I must say, it's much improved over the old PVC design.
    This is a simple piece of 1" copper, capped on one end, and flared open on the other with four 4" cuts. Combined with a rubber stopper to hold the flares open during the removal process, it's worked like a champ each and every time. And, since I'm banging on metal and not plastic, I retired the rubber mallet for a real hammer. Bangs out headset cups in a snap.
    The second tool is a low-tech headset press. God bless Mike T., but I simply can't bring myself to whack a headset cup into the frame using a 2x4 and a hammer.
    For me, the answer is a simple 3/4" x 8" UNF (fine-threaded) bolt with a stack of fender washers. A 1/2" bolt would be ever better for this application. The UNF threading requires 16 turns per inch of movement for a 3/4" bolt, or 20 turns per inch for a 1/2" bolt.
    Avoid coarse threaded UNC bolts of similar diameters -- they would require 10 and 13 turns per inch, respectively, resulting in a less even press and a greater chance for the cut to get crooked while going in.
    Here's a bunch of pictures.</td></tr>
    </table></P>
    <img src="http://www.booboodog.net/images/headset-tools.jpg">
    <img src="http://www.booboodog.net/images/headset-removal1.jpg">
    <img src="http://www.booboodog.net/images/headset-removal2.jpg">
    <img src="http://www.booboodog.net/images/headset-press1.jpg">
    <img src="http://www.booboodog.net/images/headset-press.gif">
    <table border="1" bgcolor=DAFFC4>
    <tr><th></th>
    <th>Index of MkIII Build Posts</th>
    <th></th></tr>
    <td><font size=1><b>
    <a href="http://forums.mtbr.com/showthread.php?t=130055">MAIN: MkIII / Speedhub Build Pics</a>
    <a href="http://forums.mtbr.com/showthread.php?t=84431">Iron Horse MkIII Naked Frame (March 2005)</a>
    <a href="http://forums.mtbr.com/showpost.php?p=1151&postcount=4">Hollowpoint Speedhub Build Pictures (April 2003)</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189936">Cane Creek AD-12 Air Chamber Volume Adjustment</a>
    <a href="http://forums.mtbr.com/showthread.php?t=126928">White Brothers 2006 Technology</a></b></font></td>
    <td><font size=1><b><a href="http://forums.mtbr.com/showthread.php?t=110833">White Brothers DT 1.2 Fork Porn</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189946">Stripping Anodization</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189954">Bottom Bracket Drain Hole Drilling & Installation</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189971">Drilling Out Cable Stops (Full Length Cable Run)</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189977">Dremel Cut & Prep of Cable & Housing</a></b></font></td><td><font size=1><b><a href="http://forums.mtbr.com/showthread.php?p=1189926">Hopey Steering Damper Installation</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189989">Stripping & Polishing an Aluminum Frame</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1190007">Homemade Headset Removal & Installation Tools</a>
    <a href="http://forums.mtbr.com/showthread.php?p=1189999">Star Fangled Nut Removal (Drilling out the Star Nut)</a></b></td></td>
    </tr></table>
    speedub.nate
    · MTBR Hiatus UFN ·
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by Speedub.Nate
    .......bless Mike T., but I simply can't bring myself to whack a headset cup into the frame using a 2x4 and a hammer.
    I think of it as "gently caressing" the cups into the frame with a 2x4 and a hammer Nate. I look upon my hammer taps as intermittent pressing motions. People have this nightmarish idea that one needs to pound aways with a FBH (firkin big hammer) and that's not the case. The last one I did for a friend I made sure that he had the optimum 0.1-0.25mm of interference (how many shop "mechanic" headset pressers confirm that fit?) and had the headset tapped into his frame before he could have assembled a bolt, washers and nut or loaded the car for a trip to the LBS. It took maybe 10 seconds per cup.
    "Wow I didn't know it was that easy" was his comment.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    On MTBR hiatus :(
    I have complete faith in your method, as long as you're the one doing it. I'm sure once I see you do it, I'll change my opinion.
    speedub.nate
    · MTBR Hiatus UFN ·
    Squalor
    Nate -
    I use the exact same method for a headset press except I use a long eye-bolt instead of a regular bolt.
    I then inset a long lever (I use an old handle from a floor jack - but whatever will work) and hold the nut on the bottom with the adjustable wrench.
    I can just rotate the lever while holding the bolt and eveything tightens up without having to remove the wrench...
    Same idea, just a little different implementation.
    LP
    Nate, where did you source the parts for the press? I was thinking either hardware store or autoparts store, but I was wondering if a "UNF" bolt or "fender washers" were going to be hard to find. Thanks.
    On MTBR hiatus :(
    Quote Originally Posted by bikerboy
    In fact, they weren't as easy to find as I expected. At the time, Home Depot nor my local True Value didn't stock any UNF bolts. I tracked some down at an Orchard Supply Hardware store.
    The fender washers are pretty common. Bring along a headset cup just to make sure the diameter of the fender washer is large enough to cover the edges of the cup.
    speedub.nate
    · MTBR Hiatus UFN ·
    Quote Originally Posted by lanpope
    Nate -
    LP
    I used the exact opposite method for spreading the rear dropouts of a steel road frame to 130mm using threaded rod same diameter as a hub axle and placing the bolts and washers between the dropouts.
    Word, Osh has more of this usefully stuff
    I use that method on pressing everything in, bearings, headsets, it always works like a champ and costs next to nothing. If I had money to throw away I'd get the headset press from Park tools but this works fine for me.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    cool ideas. d
    Jan 2005
    nate the bicycle tool guru...keep tinkering for us poor folx who really ride and work on our bikes
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    Jan 2005
    So, how do you set the crown race?
    Quote Originally Posted by TeamRoundBoys
    tap on with a pipe, keep the pipe on the floor and move the fork up and down to avoid damaging dropouts and rebound knobs. I used the stick and hammer method once and it took a few rides for the headset to settle in. The pipe method works much better.
    On MTBR hiatus :(
    Quote Originally Posted by Ratt
    Same here. I have a length of ABS pipe (PVC will do) with an interior diameter just larger than a 1-1/8" steerer tube. I simply stand the fork upside down on the pipe (which itself is standing on the floor) and bang on the underside of the crown with a rubber mallet.
    Of course, if you use FSA headsets, most have that nifty split ring crown race, which snaps into place with light finger pressure.
    speedub.nate
    · MTBR Hiatus UFN ·
    Reputation: wickerman1's Avatar
    I think the worst crown race I've installed was RF DH Real Seal headset... it was so hard to get it in its home position... i use this big metal collar that is just over 1 1/8 of an inch in diameter( inside dia.) and its about 3/4 of an inch thick and tall..efect for crown race fitting... then i use a pipe that i pound on the collar with( like a dent puller but opposite motion) and set the crown nicely.. except for the RF... it took a hell 'o long time to get it there...
    now what do you use to get the crown race off??
    On MTBR hiatus :(
    Quote Originally Posted by wickerman1
    For removal, I bang 'em off with a flat bladed screwdriver and a couple of well placed blows from a hammer. Others suggest a brass punch to avoid scarring the bottom of the race. With those super slender races (I assume the RF is one of them), it's sometimes difficult to find enough exposed race to bang against.
    I wish everyone would adopt the split crown that FSA uses -- it snaps on with light finger pressure and pops off with the gentle twist of a screwdriver blade.
    speedub.nate
    · MTBR Hiatus UFN ·
    Dec 2005
    That is exactly how we pressed in the headset on my Distance...just a peice of allthread and some washers.
    For the press i use the same washer screw method but i also use some pieces of wood (soft pine) so I don't scratch that nice Chris King finish.
    Sep 2004
    thanks for the inspiring video!!!!!!!
    saw the video and ran to home depot for my setup, home depot even has fender washer rubber spacers if your worried about any scratching issues.
    My "friend" would charge me 10 bucks a smash for this.
    thanks for the info, and keep on keepin it real. RETROROCKS
    <tr><th></th>
    <th></th></tr>
    </tr></table>[/QUOTE]
    Jun 2005
    Another option for setting the crown race is to use a cut down peice of 1 1/8 Copper Pipe (about 12~18 inches long). Copper is a really soft metal and will deform to the crown race shape. It also will not shatter like PVC will when hit too hard. (PVC is sharp when is shatters)
    If you have some time, you can hold the fork in one hand with the crown race and pipe in place and tap the crown race down (slow and boring). If you have less time a 2X4 between two sawhorses gives you a really good place to place the top of the rigid crown (not the suspension crown) of the fork and tap harder. In both cases watch the race seat and try to keep the race flat while is being tapped on the the fork.
    Also, you can order just the headset press step washers to fit inside the headset from mail-order / web based part houses. Then you only need a single fender washer in the press.
    Patent infringement?
    <img src="http://www.parktool.com/images/products/productimages/spr_HHP-3_2005922_35260.jpg">
    A slight variation on your design
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    Very nicely presented Nat. I'll have to make my own.
    Trev!
    Reputation: yomattyo's Avatar
    So, would this work for 1.5" headset as well? I'd like to make one of those tools, I'll be installing a Cane Creek Double XC into a blindside, anything I need to know about it being a low stack and 1.5"?
    On MTBR hiatus :(
    Quote Originally Posted by yomattyo
    Yeah, or at least it ought to with the right sized washers. I've pressed a whole bunch of zero stack headsets with the nut & bolt trick, and it hasn't failed me.
    speedub.nate
    · MTBR Hiatus UFN ·
    Aug 2005
    If I remember correctly you will need a washer the size of the inside lip that the bearing sits on as the cane creek recommended not pressing using the outside of the cup. You should check their website to make sure.
    Here is a picture of my headset remover
    I went to the hardware store looking for a 1" copper pipe and the cheapest one they had was 2 feet long and 20 dollars.
    I already had a breaker bar that I had used in the past to knock around each "corner" of the cup successively. The problem with this is obvious. Not only does it damage the cup to hit only one side of the lip but you could easily hit your hand as you're holding it so carefully.
    So I took a washer that was the right diameter to just fit inside the headtube (happens to be 33 mm for a 1.125" headtube). I held it with vice grips and filed down two sides of it so that I could slip it through the inside of a cup and get it into the headtube. It turned out that it needed to be filed down to 29 mm to do this.
    Then I simply drop the washer into the headtube. It sits cleanly against the inside of one cup. I pound the washer using my breaker bar and the cup is out in seconds with no damage.
    The washer cost about 50 cents.
    A wheelist
    That's an excellent idea 'clover. Thanks for that. I've knocked them out for decades with a large screwdriver but your gizzmo makes the removal so much better.
    Quote Originally Posted by Mutantclover
    nice. very similar to fork bushing removal tools. the headtube ID for std 1 1/8 is 33.8mm
    On MTBR hiatus :(
    Very nice. The improvement I'd like to see is an easy homebuilt way to press the cups out, instead of banging them. This is a step in that direction.
    speedub.nate
    · MTBR Hiatus UFN ·
    Reputation: IRONMAN1518's Avatar
    Nice way to show the tools Nate, THANKS!! I've used similar.I have used a similar device to hold the external BB tool onto the external BB cups straight so not to run the chance of stripping the "dents' in the cup, I posted it here.
    .Homemade Tool to Keep BB Cuptool Fixed
    Training on Hills Builds Character, That's How I Got To Be One!
    Reputation: hado_pv's Avatar
    1 1/8 hole in my solid oak work bench. invert the fork and drop it until the race is set.
    http://facebook.com/CharlemontTrails
    NEMBA Past President...
    Reputation: Wombat's Avatar
    Quote Originally Posted by hado_pv
    I used the umbrella hole in my outdoor table instead. But I had to do it when my wife wasn't watching. I eventually got a piece of conduit and found it more practical.
    Tim
    Does the rubber stopper in the bottom of the removal tool help stop damage to the cups?
    I'm just trying to picture this working(and fitting) inside the headset.
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    I do the same thing but use brass bushings between the cups and washers
    On MTBR hiatus :(
    Quote Originally Posted by thechez
    No, I use the rubber stopper to spread the "legs," and keep them spread. I actually carried this over from the PVC version I made originally, since it would always snap back to its original shape (closed). The copper is better than the PVC in this respect, but it's not as springy as a read headset cup remover, so the stopper still helps a bit to keep the end of the pipe open and engaged.
    speedub.nate
    · MTBR Hiatus UFN ·
    El Pollo Diablo
    Reputation: SnowMongoose's Avatar
    Feb 2007
    FWIW, I've had varied luck with this type of homemade headset tool...
    done a bunch of FSA HSes and one C'dale HS, no problem, but cracked the hell out of a Crank Bros headset doing the exact same thing.
    On MTBR hiatus :(
    Quote Originally Posted by SnowMongoose
    So far installed two Crank Bros. Directsets, no issues.
    speedub.nate
    · MTBR Hiatus UFN ·
    Reputation: dorkboy's Avatar
    I am a machinist currently and I was born and raised in a bike shop. So getting back into biking, I should make myself some tools.
    Here is my headset press with spacers and Chris King spacers.
    If anybody want the dimensions, just let me know,
    Scott.
    For headset removal I have used PVC, but it doesn't last. Now I use an old aluminum handlebar with a grip on one end to remove headsets. Works well and it is kind to the headsets.
    urmb
    “Nothing compares to the simple pleasure of riding a \mountain or fat/ bike.” ~ John F. Kennedy
    Quote Originally Posted by dorkboy
    Scott.
    wow! I myself have made tools like the OP, but that is a some serious hardware. You could/should sell that thing. I'm sure it's pretty time consuming to build a single unit one off like that but if you did small runs at a time you could probably make a nice little side business out it. Boutique brands seem to gain cult like followings in the MTB community.
    Reputation: Dangerous E's Avatar
    Did you end up trying this method on your XXC headset? I'm at the same crossroads right now--really want to try it but not too into ruining a perfectly good headset.
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Quote Originally Posted by reptilezs
    That's a great idea. Talk about a simple tool, I love it.
    "...like sex with the trail." - Boe
    Feb 2012
    Headset press
    I have just come in from the garage having seen and acted upon the flared tube idea for removing my headset, very effective, but met with the challenge of re seating the replacement. I then remembered a post about using threaded bar, washers, bolts and so on. I found some washers that were the right size but no bolt. Luckily, having never thrown anything out, I struck upon the idea of using an old rear hub QR skewer. This gives you the flexibility of gently turning, levering the headset in, the former worked better.
    If I hadn't had large enough washers, a couple of wood cores were going to be my next option.
    One headset successfully seated with out buying any fancy tools and without even having to leave the garage.
    Sounds like a convenient solution Fjord. But I feel the need to bring up something that happened to me when using a small allthread to install a headset. Basically when I was halfway through pressing, the allthread snapped and one half went rocketing across the room like it was shot out of a gun. Granted the skewer is probably treated steel and my allthread was probably low strength steel. I guess what I'm trying to say is if you find yourself using a fairly small diameter rod with high tension, stand clear of the two ends. The one I use now is massive in comparison to that one that snapped.
    Reputation: River19's Avatar
    I just use a woodworking clamp and a couple rags to protect the headset.......rotate the clamp around to apply even pressure......
    We're not launching the space shuttle here, just installing a headset right?
    I like some of these solutions though.....beats the heck out of the spendy purpose made tools...
    Has anyone made one for a tapered head tube?
    Mar 2012
    impressive tools. good work guys
    Jun 2012
    Quote Originally Posted by MaddSquirrel View Post
    Is this really an issue?
    Quote Originally Posted by aBicycle View Post
    Kind of. I just "pressed" in a new Cane Creek 40 EC49 (external-style 1.5" cup) using a hammer and a block of wood. Ultimately I ended up using just the hammer a little as well (I know, I know). The outside edge of the headset cup is pointed at the bottom, as opposed to shelf-like, so whatever pounding or pressing you do takes place on a very small surface. Even though it seems I did no damage, because I ever so slightly flattened out that lip I had some trouble getting the bearing into the cup. It is a very tight fit right at the lip to begin with. But once in, it has plenty of room - the bearing is sandwiched between two conical surfaces, so slight deformations to the outer edges of the cup don't really matter. The seal built into the crown race also does not contact the edge of the cup, rather, it runs along the outer rim of the sealed bearing.
    So the 40 is pretty ghetto install friendly, but not 100%. I wouldn't hesitate to do it again the way I did in a pinch, although I agree with Cane Creek in that it isn't the best way.
    Hope that makes some sense.
    You'd think it would be, especially with the cheaper headset cups like the CC S3 which are a lot thinner than like the Chris King cups. I've never ran into a problem but when I first started pressing in cups using the bolt and washer method i used a plastic seal driver inside the cups to protect them.
    When installed using a press (homemade or otherwise) it is not an issue.
    The Wiking
    Reputation: Ranger Radon's Avatar
    Quote Originally Posted by Mutantclover View Post
    Just subscribing to this excellent post... I'm going to improve it a bit though.. i think..
    with speed, shall technique be conquered
    The streets are the sketchiest of trails.
    Jul 2013
    I paid $15 to a LBS to get my headset installed. It was efficient.
    Quote Originally Posted by taptee View Post
    What was the point in resurrecting a year old thread just to post that?
    Jul 2013
    Quote Originally Posted by bad mechanic View Post
    Ah, I didn't want to frustrate anyone. I had held off on building a bike for a long time because I thought headset installation must be rocket science. Eventually, when I did bite the bullet and order the parts, I realized that I can get that done for $15.
    I just wanted to share this with other enthusiasts so headset installation doesn't sound too intimidating.
    Oh, and I am a huge fan of the story of Lazarus. That too.
    Oct 2014
    What can I do if the headset went in at a slight angle using this method? If I keep turning, will it even out eventually?
    Quote Originally Posted by youhjjhhhjj View Post
    How slight? If less that 1/16" i keep going but more than that i start again. If i have trouble getting a straight start I will tap the headset on and then crank it down with the press.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I'd start over.. spin the cup 180º before trying again.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: TandemBear's Avatar
    Aug 2013
    Hey, I thought I'd share a lucky find I had a few weeks ago.
    However, I'll add that I've had pretty good success using allthread, nuts & washers as a bearing press. Although It lacks centering and alignment advantages of a high-quality bearing press, it still functions pretty well.
    Well, one day I happened to be crossing the street and noticed an old, greasy metal object on the ground. I picked it up and realized it was some sort of bushing or spacer, I assume from a car's suspension. I took it home, cleaned it up and realized it looked like it might fit my allthread press. Sure enough, the ID is almost an EXACT fit on the allthread I happen to be using. And the OD is perfect for some headset and hub bearing applications. It's approximately 1" in length, so it resists sideways torquing when applying load to press bearings.
    I have been meaning to take it to an auto parts store to see if it is just one of many different bushing sizes available, but haven't done so yet. If so, this would probably be a really inexpensive way to get centering and aligning guides for the home made presses I see people using here. If I ever visit the auto parts store, I'll share what I find here.
    If anyone else happens to do same, please let folks know.
    May 2014
    I tried this method for my Cane Creek headset in my new frame and couldn't keep it from going in crooked. So I read instructions (I am man I don't stop and ask directions lol) and lo and behold they show driving cups in with a bearing race driver and hammer. So I went to my toolbox and got my aluminum race driver set and headset installed rather simple. That's how I did it. Used a dead blow hammer too.
Members who have read this thread: 20
