Results 1 to 5 of 5
    Compulsive Bike Builder
    Reputation: DirtDad's Avatar
    May 2002
    Mini master link remover?
    Does anyone make a mini master link remover tool, like a mini Park MLP-1. Or better yet, does anyone make such a tool incorporated into a mini tool instead of a chain breaker tool?
    Disclaimer: ComCycle USA
    i use pliers and go on the diagonal
    May 2002
    I use the "diagonal" pliers technique, too. After a little research, it looks like squeezing the link in the right way (different from what I was doing) works with no tools. I will give it a try later.
    squeezing the link works but when the chain is nasty its much harder. the diagonal method provides axial force along the pins and the release/backwards movement
    Reputation: 4slomo's Avatar
    If you have a mini tool with pliers, you can convert the pliers into a master link remover, similar to what I did with some needle nose pliers, using a file and a dremel:
    Attached Thumbnails Attached Thumbnails Mini master link remover?-p1020867-compressed.jpg
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  1. Topeak Mini Master Blaster missing part?
    By Seanstex in forum General Discussion
    Last Post: 05-01-2008, 08:05 AM
  2. Half link master link??
    By Kevin Regan in forum Singlespeed
    Last Post: 03-29-2008, 08:12 PM
  3. quick link/ master link
    By TonyTheTiger in forum Beginner's Corner
    Last Post: 01-26-2007, 09:52 PM
  4. Mono Mini leaking master cap
    By dzm3 in forum Brake Time
    Last Post: 07-14-2006, 07:55 AM
  5. Quick link, or Master chain link for 1/8th
    By mp29k in forum Singlespeed
    Last Post: 08-06-2005, 12:39 AM
