Results 1 to 8 of 8
    Apr 2013
    Mini bench grinder
    Just made this at work today. It is small and easy to store. I made it to sharpen drill bits, cleanup screw driver ends, and allen key ends. The motor is from an old Lincoln welder cooling fan. The wheel is from an air motor. Works pretty well so far.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Very nice.
    Looks kinda like a piston ring filer I made once from a sewing machine motor.
    I like turtles
    Reputation: J.B. Weld's Avatar
    I like it. Does that little motor have enough torque?
    turtles make me hot
    Quote Originally Posted by J.B. Weld View Post
    I bet we'd have a hard time keepin' up with it.
    I like turtles
    Apr 2013
    Ya I was pretty surprised how strong it is. I would guess the RPM is around 1200 to 1500 or so. you can stop it if you press to hard against the wheel, you have to push pretty hard through. I was able to resurface a 3/4" width wheel with another grinding wheel by holding it against the wheel and it slowed down a little but kept going. only issues I see so far is it gets a little hot after about 8 minutes or so of continuous us. There is no cooling fan so as expected I guess.
    Apr 2013
    Had to add a gaurd to keep shavings from going in my eye. My shity heath insurance went up another 23%, 3 years in a row. It would cost me 2 car payments to go to the doctor. Insurace premium cost so much you cant aford to actual use the insurance.
    Plays with tools
    Reputation: customfab's Avatar
    Bench grinder motors are sealed for a very good reason. But that should do just fine for the occasional light duty job.
    Apr 2013
    Quote Originally Posted by customfab View Post
    Thanks for the reminder. As you can see the top is wide open. I will make sure to keep shavings and grinding dust out of the motor. That would not end well.
  1. How much do you bench press?
    By AC/BC in forum Off Camber (off topic)
    Last Post: 06-27-2015, 05:47 AM
  2. mini z not mini me and other hobby pics
    By singlesprocket in forum Off Camber (off topic)
    Last Post: 04-13-2013, 10:52 AM
  3. Bench cutting with Stump Grinder type power heads?
    By hado_pv in forum Trail Building and Advocacy
    Last Post: 02-20-2013, 10:21 PM
  4. Recommend a bench vice for about $50
    By crclawn in forum Tooltime
    Last Post: 10-09-2011, 10:18 AM
  5. Bench Vice
    By nov0798 in forum Tooltime
    Last Post: 02-13-2011, 03:40 AM
