Results 1 to 5 of 5
    Reputation: Zomby Woof (MCM700)'s Avatar
    Metric Bolt torque table
    I was looking for that information. It was easy to find. Here it is for everyone that knows how to turn wrenches.
    Metric Bolt Torque Table - CNCexpo.com
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I appreciate tables that differentiate lube and dry torque values. Lot's of folks fail to understand the different values.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    What this calculator doesn't list, are these torque values for bolt and nut joints or bolt and threaded into a given material. Big difference
    Magically Delicious
    Quote Originally Posted by mtnbiker4life View Post
    Nothing is going to give you that except the component manufacturer. The table defines the fastener torque limits based on Clamp load which approximates 75% of proof load.
    Quote Originally Posted by Cleared2land View Post
    I understand what the table is saying, I do these calculation every day as an engineer but what I am telling you is their is a difference in the two joints I listed in my first post. So I would look at the data given by the component manufacture then a table.......unless you have the right table for the right joint.
    One more thing this table is specific to graded metric fasteners. So make sure you know what grade the fastener is before running the torque on the joint.
  1. Intense Carbine bolt torque
    By grunf in forum Intense
    Last Post: 11-11-2014, 09:47 AM
  2. tracer 275 torque table
    By castolin in forum Intense
    Last Post: 09-19-2013, 03:05 AM
  3. Intense Tracer 2 torque table
    By seb-zero in forum Intense
    Last Post: 06-01-2012, 04:12 AM
  4. Bolt Torque with Plastic Bash?
    By half_man_half_scab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-18-2011, 07:30 PM
  5. Fun Bolt Torque
    By half_man_half_scab in forum Wheels and Tires
    Last Post: 02-07-2011, 10:08 AM
