Results 1 to 3 of 3
    May 2013
    Mach 429 front der adjustment - advice
    The access point for the pinch bolt makes it to where you can only access if you hold the der toward the large chainring because if you allow it to relax to the i ner chainring, the pinch bolt rotates down and you cannot tighten it via the access hole in suspension link.
    any advice on how you other pivot owners make your front der adjustments?
    Plays with tools
    Reputation: customfab's Avatar
    I've got a 4 and 5 hex key that I've cut down the short end on. Just long enough to bottom out on a socket head screw. It's great for when manufactures don't take things like this into consideration.
    May 2013
    Thats a great idea, ill give it a whirl! Thanks.
  1. Front Derailleur Adjustment
    By ttran037 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2014, 02:15 PM
  2. New to travel adjustment and need advice
    By progfan1 in forum Beginner's Corner
    Last Post: 07-09-2013, 11:19 PM
  3. Front Mech Adjustment Comes and Goes
    By Thrawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-27-2012, 07:54 PM
  4. yelli front der adjustment
    By Hoka Hey in forum Canfield
    Last Post: 11-24-2012, 03:30 PM
  5. Front derailleur adjustment Q
    By beanbag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2012, 08:51 PM
