    mtnjam
    Reputation: ryman's Avatar
    M8 X 1.25 PermaCoiling on Chainstay/Rocker threads
    I have a stripped chainstay thread on my Titus Switchblade. It's the M8 x 1.25 bolt that connects the rockers to the chainstay that I either accidently crossthreaded or over tightened. Either way the bolt doesn't snug up very tight. The bolt is in there well enough to not just slip out, but I want to keep it as tight as possible.
    I have a PermaCoil kit now with a 21/64" drill bit to drill out the old thread. I have the inserts, installer and the PermaCoil tap. When I take the M8 x 1.25 thread inserts and turn them onto the M8 bolt (no drilling or tapping, peramcoiling done yet) the bolt still seems kinda loose in the insert. Is this normal for a heli/perma coil to be loose prior to inserting it?
    Just ride down there and jump off something for crying out loud...
    The insert will be properly sized when it's threaded into the threads cut by the special tap.
    mtnjam
    Perma Coiling done. Worked very well. The threads fit just fine now.
    The hardest part of the job was getting through the psychological factor of putting a drill bit to the frame and cutting out the stripped threads.
    Photog Cyclist.
    Reputation: 23mjm's Avatar
    Buy a torque so you won't over tighten again--I haven't found a manufacture you doesn't give torque specs for their pivot bolts.
    We ride and never worry about the fall
    I guess that's just the cowboy in us all
    (Tim Mcgraw)
