Results 1 to 10 of 10
    Loctite Form-a-Thread
    so i borrowed some form-a-thread. don't ask why. it's missing the release agent, the blue goo that goes on the bolt so that the form-a-thread doesn't stick to the bolt. loctite says it's a silicone emulsion release agent.
    anyone know of a good substitute?
    Stay thirsty my friends
    Reputation: 4JawChuck's Avatar
    Nov 2008
    Any will do.
    "Say good night to the bad guy."
    Tony Montana
    http://www.youtube.com/watch?v=2x_TE...eature=related
    i can haz new threads!
    nice! i have some of this, that i use to lube my stanchions and rear shock:
    haha, that didn't work at all. maybe i had let the bolt sit for too long after spraying it well with the silicone lube but it got stuck in the form-a-thread and i wound up having to grind it off.
    Nov 2008
    You used a silicone lubricant not a dry film release spray, they are completely different animals.
    Tony Montana
    egad, i saw the silicone lube in the second picture and bit. didn't see the "dry release" part with the hook in my mouth. atleast i know now that one must have a proper release agent to use form-a-thread!
    dan savage says too much dry release will wreck your weiner, making wet release more difficult to achieve.
    Nov 2008
    Dry silicone spray adheres to the substrate by polar attraction and hence is very difficult to remove especially from metal. Silicone lubricants are suspended in a dispersant which dilutes and prevents polar attachment to some degree not to mention is likely dissolved by your epoxy binder chemicals.
    Lesson learned, you can use heat to remove a bolt imbedded in the epoxy as it will break down at temps over 300F. For a bike component I would use a heat gun to prevent damage from a flame.
    Tony Montana
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Butting in here: How strong is this stuff? Could it be used on partially stripped crank extracting threads?
    Nov 2008
    Unlikely.
    Tony Montana
    Quote Originally Posted by 4JawChuck
    ahhh, meh. thanks for the info.
