Results 1 to 14 of 14
    Reputation: jeremy3220's Avatar
    Jul 2017
    Lock-on grips slipping
    I have ODI Rogues and recently swapped bars for some Deity Blacklabel bars. I'm having issues with the grips moving a bit on stuff like drops. I tighten the grips thinking they were just loose but that didn't solve the issue. This wasn't a problem on my OE bars. I think it's because the bars have a glossy finish in the grip area. Anyone deal with this before? I'm thinking of taking sandpaper and lightly scuffing the paint under the grips.
    Jul 2015
    You could probably use carbon paste, it does a good job of giving seatposts/grips extra friction so they don't slip. Park tool supergrip compound is a pretty common one.
    http://www.jensonusa.com/Park-Tool-S...hoC19QQAvD_BwE
    Sent from my XT1585 using Tapatalk
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Scuff the locks...
    Todd
    Jul 2017
    Quote Originally Posted by -Todd- View Post
    Scuff the locks...
    That's a good idea. I'll try that then use carbon paste if it doesn't work.
    Reputation: Arebee's Avatar
    Sep 2012
    I have the same Rogue/Diety combo, but I don't have any issues with anything clamped to the bars. I think scuffing is the way to go for you.
    AreBee
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Agreed on scuffing both the locks and the bars.
    I've also resorted to putting down a layer or three of cyanoacrylate where the locks interface. Essentially builds it up to allow the locks something to wrap around. Let it cure between each layer.
    Jul 2017
    I ended up scuffing both the grip locks and the bars (no one will see under the grips so might as well). I haven't had any issues with the grips slipping since.
    sort of funny, that smoothness is what makes non-locking grips not slip but does the opposite to lock-ons.
    Jul 2017
    Quote Originally Posted by Ratt View Post
    Friction of hard materials is dependent on surface roughness. For rubber it's more complex.
    Reputation: MSU Alum's Avatar
    Yes. Hysterical.
    Mudhorse
    Reputation: Grassington's Avatar
    Jun 2017
    I've got a couple of sets of ODI Rogues fitted to bikes, both on CF bars. The first set I assembled the clamps to the central grip section dry, then used CF paste on the bars. I have had issues with the clamps loosening and also the centre section has developed a bit of play relative to the clamps as the plastic has worn. A bit of Loctite 243 on the clamp bolts and a re-torquing to the bar spec of 2.5 Nm sorted out the clamp looseness but there's still a tiny bit of play between the centre section and clamps. New centre sections will sort that out when the play gets too much.
    The second set of grips I used CF assembly paste both between the centre section and the clamps before assembly, and on the bars too. I didn't use Loctite on the bolts, but so far they're hanging in there and no play is evident.
    I do tend to throw my bike around a lot, and often this involves some serious twisting on the grips so the poor things do get worked hard.
    Hose me down till the water runs clear.
    Old school trick, hair spray on the bars.
    Mudhorse
    Jun 2017
    Quote Originally Posted by leeboh View Post
    Would that work with locking grips? I've certainly used it in the past with rubber and foam grips, though the Silvikrin brand I used would eventually dissolve in the wet and I'd have to go through the whole tedious process of remounting the grips. I converted to locking grips when I replaced my 2007 Race Face CF bars with newer Easton Haven CF bars and I could not for the life of me get my Ritchey rubber grips to stick. I'd have used contact adhesive if the bars weren't CF, but as that wasn't a sensible option I went through several locking grips before I found the ODI Rogues that suit me nicely.
    Armature speller
    Sep 2004
    I have a pair of Bontrager RXL carbon bars that are slightly under spec in diameter.
    I found this out when powering up a hill whilst holding on to the bar ends...
  1. Ergon GS1 MTB Racing Grips or Specialized Contour XC grips
    By marcos77 in forum General Discussion
    Last Post: 01-28-2014, 07:41 PM
  2. Imprint Grips - Custom Moldable Lock In Grips on Kickstarter
    By NoTryOnlyDo in forum General Discussion
    Last Post: 12-16-2013, 09:45 AM
  3. What's not a good idea? Installing grips like golf grips
    By boo radley in forum General Discussion
    Last Post: 11-20-2013, 05:12 PM
  4. Handlebar grips and slipping off
    By firekja in forum All Mountain
    Last Post: 11-24-2012, 08:08 AM
  5. soft grips vs. hard grips?
    By shwinn8 in forum Downhill - Freeride
    Last Post: 11-03-2011, 09:46 AM
Members who have read this thread: 26
