Results 1 to 18 of 18
    Reputation: BikeShopMonkey's Avatar
    lightest chain breaker?
    needing to cut weight from my endurance bike seat pack.
    which are the lightest in weigh(grams) that are out?
    thx
    so my afro now sticks out of my helmet.
    Reputation: marpilli's Avatar
    Stand-alone chain breaker? Or, integrated compact tool?
    I received a Topeak Mini 20 Pro (150g) for Christmas and have used the chain beaker twice and really like it. I have several Topeak products and have been really (really) happy with their customer service when it was required.
    Reputation: gmats's Avatar
    Apr 2005
    Aloha,
    Here's what I found a few years back.
    Attached Files Attached Files
    Former Bike Wrench
    For a multi-tool with chain breaker, check out the Lenzyne SV-10...101g complete
    just the chain breaker alone pls
    I use the Park CT-5 at 77gr.
    Packs easy, works great.
    Category Winner
    Reputation: teamdicky's Avatar
    I stole this from an old Topeak Alien:
    I did have to stick a bolt in it, so I had something to hold onto.
    Fits nice in my kit, although I've never had to use it.
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    I've been carrying this Chain Pup in my saddlebag for over 20 years. Don't know if you can even find these any more. If I remember correctly, it was created by Wilderness Trail Bikes and then licensed to Finish Line. I have used it dozens of times on the trail.
    Total weight is 30g, but if you have a 4mm hex wrench (to turn pin removal screw) in your tool kit already, the Chain Pup chain breaker portion alone is only 14g. The second piece has a 4-5-6mm hex wrench and 2 sizes of spoke wrenches.
    Attached Thumbnails Attached Thumbnails lightest chain breaker?-chainpup.jpg
    Might look at this guy from Performance. Going to be hard to beat 138g for all that you get. You can always pull the chain tool off if you need to. It's what I carry in my Awesome Strap along with a tube.
    Spin Doctor Rescue 16 Multi-Tool - Take Along Tools / Multi-tools
    -Tom
    I used to wear my Chainpup (invented by husb) as earrings to show off that lightness!
    Quote Originally Posted by sgltrak View Post
    yeah, I see stuff in web about how WTB 'invented' this cute thing
    Charlie's a nut about weight (he weighs less than me)...his Pup ended up detonating a rash of Not Quite As Light stuff, beginning with the "CPR" and the "Cooltool" which made THEIR makers a cool fortune. Charlie got...as usual....squat for his contribution.
    Oct 2013
    9.4 grams and only $3.50
    This is a "CNC transmitter bracket" from ebay. The screw that comes with it is a bit short, so you'll want to find something a few mm longer. Then just grind off the threads and make a point or rounded tip.
    Note: only grind off enough threads to just reach through the chain. The more you grind off, the less engagement you will get in the body. With ~6mm ground off, I had 8 full threads of engagement (should be plenty). You could also drill and tap a larger screw if your worried about the size.
    Quote Originally Posted by Sconnie391 View Post
    Hey Sconnie I can't see the photo. Can you point to a couple of items on ebay or maybe expand on it some more? I'm intrigued but just not sure what you're doing?
    Oct 2013
    Yeah, can't get a link from google photo's to work... I know the ebay links disappear fast, this might stick around a while:
    https://www.aliexpress.com/item/2014...708.4.6.mikefX
    The only thing you need is the piece that looks like half of a hinge. One side is threaded, the other side has a larger clearance hole.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Here's his photo...
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    bikes don't have motors
    Reputation: life behind bars's Avatar
    May 2014
    Not the lightest but considering the whole.....
    lightest chain breaker?-industry-nine-matchstix-thru-bolt-axle-hubs-wheels-cxul-backwoods_-25.jpg
    https://www.google.com/url?sa=t&rct=...O0Xj8Phrl2IgbA
    Quote Originally Posted by me View Post
    Of all the paths you take in life, make sure that most of them are dirt.
    Quote Originally Posted by mack_turtle View Post
    Gravel bike hate is imagined.
    Sweet.
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by Cleared2land View Post
    I tried one of those. It failed. Aluminum bent before the pin came out.
    Oct 2013
    Quote Originally Posted by BlueCheesehead View Post
    Bummer man, sorry.
    I used mine on a KMC X10SL. Just tested it once, but it worked.
    Bummer man, sorry.
    No worries. I found that Green Mountain Bikes in Vermont has some new, old stock Chain Pups. For $10/ea, I ordered two. I had to call to order. Super nice guy.
Members who have read this thread: 62
